Unexpalined battery drain - Team Camaro Tech
Old Nov 7th, 06, 10:44 AM
Brackneyc's Avatar
Brackneyc Brackneyc is offline
Craig
Default Unexpalined battery drain
Well, wouldn't you know it. My battery (or the car) has decided to drain the battery down to dead in two days, or less... when just sitting there. It has been fine since I put it back together a few months ago. The only thing I have done is add a temp guage. I wired it into a switched spot in the fuse box. I have looked at the choke, the ignition and almost every other thing I can think of. Nothing is "hot" unless it is supposed to be. I do havea burned out headlight, but that's about it.
Any ideas of where else to look.
Could the battery just be bad? It sat uncharged for a year prior to installation. It has however held a charge for the last three months. The battery is about 2 years old.
Craig
Now you will see that evil will triumph, because good is dumb.
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
Old Nov 7th, 06, 11:02 AM
Brackneyc's Avatar
Craig
Default Re: Unexpalined battery drain
Well, I just did a suggestion I learned from a search here. I disconnected the negative cable, and touched the tester to the battery and the body...and I have light. That indicates a drain somewhere. Will pulling the fuses tell me where the drain is coming from, or do I need to disconnect various things on the car, like the horns, lights ect...
Craig
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
Old Nov 7th, 06, 11:06 AM
satz28's Avatar
satz28 satz28 is offline
Rob
I would pull the fuses to at least isolate which circuit. Once you narrow it down, then you can see what items are on that branch.
Rob
69 Z-28 X-77 HO * DZ Put away * M20 * 4.10
406 CI * CC XR274R 236/242@.050 564/570 110 LSA/106 ICL * Brodix IK 200
475 HP, 495# tor
Street Tires, Full Exhaust Sep 07 -12.68 @ 113 MPH * Street Tires, Open Headers Oct 08 - 12.65 @ 116.2 MPH
Old Nov 7th, 06, 07:06 PM
dnult dnult is offline
Craig disconnect whatever you can get your hands on to isolate the drain. Fuses are probably the easiest first start. Pull the big red wire off the alternator also (don't let it touch ground though). Often, the alternator will develop a short in one of the diodes. If those things don't narrow it down enough, then move on to connectors.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Old Nov 8th, 06, 11:43 AM
dragon0123 dragon0123 is offline
Mark
Id try disconnecting the temp gauge that you hooke up first, since you noticed it after that.
Mark
1967 Camaro
My Photobucket >> http://s145.photobucket.com/albums/r239/camarodragon/
Old Nov 8th, 06, 01:30 PM
JimM JimM is offline
Jim
I'd go for the alternator first.
Then the regulator.
The only circuits that can even get power without the key on are the ignition, the headlight switch and the clk-cty-ltr fuse
Old Nov 8th, 06, 01:38 PM
zdld17 zdld17 is offline
Don
Ditto on what Jim said first . You mentioned choke, I presume that is hooked thru a "on '' key mode. If not and its direct, it "should' eventually heat up in the choke and turn itself off, if not it may be on constantly and a constant drain?
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Nov 8th, 06, 02:20 PM
Brackneyc's Avatar
Craig
Then the regulator.
I hate to sound clueless, but what am I checking when I check the alternator.
Craig
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
Old Nov 8th, 06, 02:39 PM
Jim
hook up your light like you did before.
Unplug the 2 wire connector and the big red wire on the alternator. Did the light go out?
Old Nov 9th, 06, 04:33 AM
Rich Vader Rich Vader is offline
try the horn relay
Old Nov 9th, 06, 04:43 AM
Jim
Originally Posted by Rich Vader View Post
try the horn relay
Yup next after the alternator. Take one of the big red wires off the horn relay. Does your test light go out?
Old Nov 11th, 06, 12:08 PM
Brackneyc's Avatar
Craig
Jim, the light went out when I unpluged the two wire connector only on the alternator. It stayed on with all fuses out. Now what?
Craig
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
Old Nov 11th, 06, 12:30 PM
Ok, you're on to something. Did you try leaving the two-wire connector plugged in and disconecting the big red wire to the alternator only? I believe you have just about narrowed the problem down to the alternator or regulator. Are we to presume this is an OEM charging system on a 1st gen with an external regulator?
Dave
Old Nov 11th, 06, 03:26 PM
Brackneyc's Avatar
Craig
Yes, totally stock configred 1st gen charging system. With big red wire off, an the other two plugged in, the light stays on.
Craig
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
Old Nov 11th, 06, 05:26 PM
pappy's69 pappy's69 is offline
Tech Team
Dan
Post Re: Unexpalined battery drain
I just went thru the same thing with my battery drainning.I check out all the circuits and then replaced the horn relay.My problem is solved.no voltage drain.I would check the horn relay,on the radiator support.
I went to auto zone and purchased horn relay for 15.95
Hope this helps and you find your battery drain!!!
______________________________
Dan
69 coupe, 350 crate motor/Th350c trans with 2.75 low first gear--2500 lock-up converter
Not a show car, just a part time Driver!!!
Similar Threads
Battery Drain problem....Help! Granny's 69 Electrical & Wiring 14 Mar 21st, 06 08:19 AM
Battery drain. icunjl Electrical & Wiring 9 Apr 15th, 05 10:36 AM
Painless / Battery Drain From Hell HELP PLEASE aonghus Electrical & Wiring 7 Mar 21st, 05 08:52 AM
battery drain...where is it coming from ms69 Electrical & Wiring 5 Nov 29th, 03 11:15 AM
Battery / do they 'drain' by design ????????? Joe R Electrical & Wiring 4 Aug 30th, 01 03:37 PM
