Third Generation 1982-1992
Old Nov 7th, 06, 05:53 PM
T-O'toole3 T-O'toole3 is offline
Default space for woffers
i have a 87 Z28 and i have 2 10" subwoffers that i had in my old car and the box dos not fit in the camaro and i was thinking on eather getting a new box or putting them in custom on the top of the trunk i think that would look cool but i dont no what is under there and if it will sound good
Old Nov 9th, 06, 11:01 AM
rocketman93116 rocketman93116 is offline
Default Re: space for woffers
On my 86 I made mounting plate for two amps on flat part of rear deck directly behind rear seats out of carpeted ½” plywood. Cut and grooved underside for wiring and separated audio from power wires. Ran power cables to front of car down right side (battery side) and audio cables down left side (drivers side) of car. Wiring comes up right next to amp connections through drilled holes.
For woofers made custom mounting plate shaped to fit trunk well space. Woofer plate fits right up against amp mounting deck plate. Mounted two 12” woofers with capacitor mounted in between. Made small ledge pieces and screwed them in to wheel side plastic and rear area on both sides of trunk latch area, then put two handles on either side toward rear of mounting panel (trunk latch area).
Be careful if screwing in plate on flat top area behind seats. It is right above gas tank. Use only long enough sheet metal screws to just catch bottom and go all the to farthest outside edge of plate as possible.
I ran monster cable up to audio head. Power for capacitor and amps comes from enclosed clear see through double fused junction block mounted on the right wheel well cover next to amps. Main power cable to battery fused at battery positive terminal.
It sounds really good.
1986 Chevy Camaro IROC-Z 28, 5.0 TPI, Auto, posi. Engine all stock except K&N air filters.
Old Dec 2nd, 06, 10:29 PM
76' Bad Bird 76' Bad Bird is offline
Shannon
I recently built a ported box for two 12's. It measured in at just under 2.4 each side,didn't leave any room but it sure does beat down.
Old Dec 4th, 06, 09:50 AM
Buddy_Lee Buddy_Lee is offline
Tech Team
Buddy.......literally
well if its not a t-top car you can find a box or build one with a little custimazation for it and drop the box where the t-tops would go me and my brother have it done to our cars and it would sound really really nice.
Old Jan 20th, 07, 07:01 PM
cagle07 cagle07 is offline
Kelly
Talking Re: space for woffers
Im my 84 camaro i just simply took a piece of mdf and cut to fit tightly in between the trunk and mounted my two subs as close as the could to the side of the trunk.( on each side). Then mounted my amp in the middle of the two subs and it bumps extremely good. dont port ur subs you will get plenty of air circulating throughout ur car for ur subs to breath.
Old Apr 2nd, 07, 11:26 AM
scooterist50 scooterist50 is offline
alex j
Arrow Re: space for woffers
anyone have some measurements or pics of these custom boxes? i have an 89 t-top rs and i have my system out of my old car that wot fit. my subs hit hard-they will blow a lighter out inside! anyways i need something that will handle all the bass
Old Apr 2nd, 07, 04:55 PM
92rsRFBC 92rsRFBC is offline
Mike
Here's a pic of my custom box in the trunk of my '92 RS. I'm building a new for my new 12" subs next week so I can get you the dimensions if you want them.
Old May 27th, 07, 08:49 PM
scruffy scruffy is offline
Joe
Crutchfield has an enclosure also available for the 82 - 92 F Body Cars. Here's the link: http://www.crutchfield.com/S-cwQ06Br...cc=01&g=182750 looks like they got em for both the 10" and 12"
Similar Threads
Space shuttle and space station picture... DjD Bench Racing 7 Sep 29th, 06 10:10 PM
Spare tire hold down bracket & space saver ??'s DElsner Camaro Tech 3 Jan 27th, 06 05:35 AM
Decode a 1969 space saver and canister 69RS/SS396ragtop Wheels & Tires 4 Dec 8th, 05 07:02 AM
Space Saver Space Tire Green Hornet Wheels & Tires 6 May 12th, 04 08:39 AM
Z/28 and Space Saver kurt6325 Wheels & Tires 2 Nov 12th, 02 06:35 AM
