scotch brite pads? - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Nov 9th, 06, 08:00 AM
stevea stevea is offline
Default scotch brite pads?
What grit is the red scotch brite Pads? I am scuffing down my jambs and want to use the red ones I have, will it show any scratches in the paint?
Old Nov 9th, 06, 08:39 AM
69X11SS 69X11SS is offline
Default Re: scotch brite pads?
I don't know what the grit comparison is for the red pads but I would use the green ones for scuffing the jambs. The green ones are a little less aggressive. I use them for a lot of stuff.
There is a fine line between hobby and obsession!
69 SS, 350, 4 Speed
69 350/350 4 Speed Corvette Convertible
Our Cars Click on my Cardomain user name to view both cars.
Old Nov 9th, 06, 09:40 AM
AlexFolino AlexFolino is offline
Alex Folino
Id use the green too. The reds are just a hair to soft.
GM service technician.
25 years old. I only drive chevys. Everything else and i do mean everything can rust in piece.
68 owner-The only way to go
Camaro: A small vicious animal that eats mustangs.
Old Nov 9th, 06, 11:38 AM
Vintage 68's Avatar
John
Thumbs up Re: scotch brite pads?
I was given this info years ago by a 3M rep.;
TAN = @100
GREEN = @200
MAROON = @400
GREY = @800
WHITE = @1200
I have always used the Green and Maroon (red) for most prep work and never had any adheasion issues.
Be aware there are two(2) 'flavors' of the Maroon (red) pads - #7447 is the more common production type pad, the #8447 is a more technical pad and more expensive.
All the above, except the two finest pads, are Aluminum Oxide cutting compounds. The Grey pad is Silcone Carbide and the White pad is Flint powder and usable on most plating without scratching the finish for removing small rust and defect spots.
Hope this helps;
John
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Nov 9th, 06, 12:57 PM
TAN = @100
GREEN = @200
MAROON = @400
GREY = @800
WHITE = @1200
Hope this helps;
John
John, this is exactly what I needed.
Thanks,
Steve
Old Nov 9th, 06, 08:28 PM
Bgonz 69 Bgonz 69 is offline
Bob
TAN = @100
GREEN = @200
MAROON = @400
GREY = @800
WHITE = @1200
Thanks.... Good info....I knew that.....but never really Knew that
bob
Old Nov 9th, 06, 10:25 PM
zbo2 zbo2 is offline
joe
when i did my car i was told to use the gray pads with the sanding paste that you can get at most automotive paint stores........worked like a charm with no adheasion problems.
joe
Joe
69 Z-28 Fathom Green />93 Z-28 Pace Car/>86 Corvette...Red
Old Nov 9th, 06, 10:54 PM
ctrghtous ctrghtous is offline
Christopher
at the shop I used to work for grey was used to scuff for paint red used to scuff for primer
Chris
68 camaro, sbc 385 (going together), holley 4150 750cfm, 4 spd, gm HEI, performer RPM intake
Old Nov 10th, 06, 08:52 AM
Some paints don't need as fine of sand grit as the gray. It seems that most paints are at about 500 grit for paint prep, am I wrong on my thinking?
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: scotch brite pads?
Location
Location
First Name
Human Verification
Similar Threads
Gas Tank Anti-Squeak pads johnb73 Camaro Tech 6 Aug 26th, 06 08:58 AM
SSBC Brake Pads Lovemy68 Brakes, Suspension & Steering 1 Feb 8th, 06 02:34 PM
semi-metallic vs. non-metallic brake pads travis Brakes, Suspension & Steering 3 Feb 1st, 06 07:17 AM
Solid or Aluminum Leaf Spring Pads??? camaroman7d Brakes, Suspension & Steering 2 Feb 3rd, 04 10:36 AM
Autozone says to use these Performance Friction Pads, do you agree ? cottonpicker14 Brakes, Suspension & Steering 3 May 2nd, 02 06:55 AM
