Pro Touring Todays performance with classic style
Old Nov 10th, 06, 11:00 PM
ChevyThunder ChevyThunder is offline
Mr. Tibbs
Default What to do to upgrade the front suspension?
Opinions welcome... I just put a nice big inch small block with a TKO 5 speed in the 69 Z ... my power steering unit is now going south on me and want to upgrade as well as upgrade the front stock 69 Z suspension , A arms etc..... any ideas or suggestions ?
" Burn rubber not your Soul "
A few First Gen Camaro's
Old Nov 11th, 06, 12:29 AM
67ss84z28 67ss84z28 is offline
Vic
Default Re: What to do to upgrade the front suspension?
cmon somebody post something i want to know too.
Old Nov 11th, 06, 04:11 AM
Rocketrod Rocketrod is offline
A little more information would be helpful. What are your plans for the car? Is it a driver, road racer, weekend cruiser, etc? And of course what is your budget?
Rod
69 Camaro - 355 SBC, 2004R, 12 bolt posi w/ 3.73, Baer 4WDBs w/ Hydraboost, Hotchkis & GW susp, Budnik Cobalts, Marquez Design pieces, DSE dash & Billet hood hinges, Corbeau TRS seats...
Smoothing firewall and Upper dash panel replacement
Old Nov 11th, 06, 04:49 AM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is online now
Team Member
Jan
One thing that has to be done is fixing the geometry of the front suspension.
One easy thing is the Guldstrand Mod, can be done with stock controlarms.
Next step is new upper arms, there are different models here that will give you more caster.
ATS has new spindles (with C5 components) that fixes the roll center so that you don't need to do the Guldstrand Mod (leaves the subframe intact).
Of course you need stiffer springs and a better adjustable shocks.
The all out multibucks approach is DSE's new subframe that has a completely reworked geometry.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z-28, Cortez Silver, LS1 / T56
protouring.se
Old Nov 11th, 06, 04:54 AM
Dan Schoenecker Dan Schoenecker is offline
Dan
You might check out Global West as well. They have a nice unit for your ride.
Old Nov 11th, 06, 05:35 AM
67ragtp 67ragtp is offline
If your looking for a steering gear the 600 box is a real nice upgrade over the stock box. I just finished building my pro-touring car, using all the DSE front end stuff, the new steering gear is so smooth it really does have the feel of a rack, you wont be disappointed.
As far as suspenion upgrades go, theres lots of options and it gets pricey. If you want to keep it simple I imagine a good set of UCA's from DSE or global west will improve the geometry, shocks and a hotchkis sway bar should get you turning the car better than stock.
Old Nov 11th, 06, 10:24 AM
Mr. Tibbs
I am not going to track the car . It is a weekend driver . But I would like it to handle better and for the front end to feel tighter...it wanders a bit right now. I do not want to go the whole subframe route on the car but would be fine with buying whatever is the best stuff to put on the stock subframe... after the big inch small block and keisler 5speed I think the budget is out the window... can't truly appreciate what I just did if the rest of the car/front end doesn't feel tight.
Old Nov 11th, 06, 10:55 AM
eville eville is offline
Gold Member
Steve
To fix the front geometry the best thing you can do is the ATS spindles. You'll need C5 brakes. Touring-Classics has a kit. Unfortunately you'll need 17" wheels. Then of course a steering box the ATS unit is nice, but expensive. Search 3rd Gen box and you'll get a ton of info.
Steve
1968 Coupe., filled with cool stuff from Tremec, Moser, Ron Davis, Speedtech, ATS, Hotchkis, Forgeline... blah blah blah
Check it Out Here
Old Nov 11th, 06, 10:59 AM
Mkelcy Mkelcy is offline
Mike
Easiest and most effective (with a bit of an eye on budget) would be the ATS tall spindles, new upper and lower ball joints, Moog "Problem Solver" offset UCA cross shafts, good shocks of your choice, C5 front disk brakes, Delrin/Delalum UCA/LCA bushings, Hotchkis 1.125" hollow sway bar, 3rd generation IROC PS box and rebuild of front steering (idler arm, pitman arm, tie rods, etc.).
Aftermarket control arms won't improve the front end geometry and are mostly a "bling" item. The ATS tall spindles are reported to improve geometry enormously, require no drilling or trimming of the UCA mounts, come with C5 hubs and allow direct bolt on of C5 brakes. Much more expensive than the Guldstrand mod, but more effective and a more elegant solution, IMHO.
Mike - 68 Camaro with some stuff done to it; building another '68 with even more stuff done to it.
http://www.camaros.net/forums/attach...2&d=1176782254
Old Nov 11th, 06, 11:51 AM
JimM JimM is offline
Jim
Van has no budget. He could always sell a Porche after all....
Agree with what was said above. The ATS spindle are great, but only work with 17" or larger rims and C5 brakes.
If you don't want to go that far, the g/s mod works nearly as well.
Hotchkiss TVS is a good "one buy" system for springs and shocks and sway bar and such.
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI
04 Silverado SS The Black Beast
93 Polo Green Corvette
http://www.Jimragtop.com
Jim's NEW Blog!
Jim Cam
Old Nov 11th, 06, 12:02 PM
Mr. Tibbs
Jim... I just sold the two Coke cars and closed on Friday .. broke my heart to do it but I will never race them again so ........ budget on Camaro parts, you are right , none... but I don;t want to take the front end off the car either.
http://img.photobucket.com/albums/v6...e/DSC03609.jpg
http://img.photobucket.com/albums/v6...e/DSC03617.jpg
http://img.photobucket.com/albums/v6...e/DSC03611.jpg
Old Nov 11th, 06, 06:58 PM
davidpozzi davidpozzi is offline
David Pozzi
I had a beautiful reply allmost done and lost it.
Maybe I'll try later...
David
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
Old Nov 11th, 06, 07:39 PM
Jim
Van, you can do anything you want to the suspension with the front end on, as long as you don't get bored with sitting in the fenderwell crosslegged!
That's too bad about selling those cars... after you worked so hard to get into that last race too (or am I rmembering the wrong car?)
Tell you what... not that I'm an expert, but Mike K followed me down a mountain and said my car handled pretty well... I followed him up one, and his handles GREAT!
G/S mod made a HUGE difference in how the car "feels" It "turns in" better, it hold the line MUCH better. Understeer is pretty much gone, or at least can be made gone with a lil throttle. That and a 1" bar & KYB's and poly are what I have now, along with the thirdgen steering box, which really makes the car feel lots more precise.
This winter will go to Dem-a-lum bushings, and probably better shocks, koni's or bilsteins. Thinking seriously about some fancy arms, I know it's mostly bling, but they'll be off anyway, sooo....
Jim's NEW Blog!
Jim Cam
Old Nov 11th, 06, 07:42 PM
Jim
Jeez! then I look at the pics.... I did have the wrong car remmebered, and I really like your living room motif!!!
Jim's NEW Blog!
Jim Cam
Old Nov 11th, 06, 08:34 PM
clill clill is offline
Gold Member
Charley
It sounds to me like you would be happy with a 1" sway bar & KYB shocks. If it wanders you might have worn out parts that need to be addressed. Start with checking ball joints and tie rod ends. Then do a 1" swaybar and good shocks. I bet it will amaze you.
Similar Threads
Front end rebuild ... tips??? suspension tuning?? BuddyP Brakes, Suspension & Steering 5 Mar 29th, 05 08:42 PM
Suspension Parts List davidpozzi Brakes, Suspension & Steering 3 Feb 23rd, 04 02:54 AM
Backspacing with larger front disk upgrade 130fe Wheels & Tires 4 Feb 7th, 04 05:16 PM
front susp. upgrade - alignment problem jstcruzin81Z Brakes, Suspension & Steering 11 Nov 20th, 02 08:24 PM
