Loose hood hinges - Team Camaro Tech
Body Shop Paint & Body Forum
Old Nov 16th, 06, 09:48 PM
68 Ragtop 68 Ragtop is offline
James
Default Loose hood hinges
Has anyone successfully rebuilt their hood hinges?
How are the reproduction hinges compared to original GM?
Old Nov 16th, 06, 09:51 PM
Mark .L.W. Mark .L.W. is offline
Default Re: Loose hood hinges
You can still get the GM ones , just get them .
Mark .
pictures can be viewed at http://photobucket.com/albums/b247/mark69rs/
Old Nov 17th, 06, 08:15 AM
James
This is not for a "cost is no object" restoration where I end up having 50K in a 25K car. I am simply maintaining a weekend driver.
My hood hinges are a little loose, can they be easily repaired?
GM hinges are triple the price of reproductions, is the difference in quality worth the price difference?
Old Nov 17th, 06, 09:41 AM
Guest174 Guest174 is offline
Rich
the difference in both quality and fit is definitely worth the additional
in cost of the gm parts
Old Nov 17th, 06, 01:50 PM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
$70 ea. for new hood hinges from GM Parts Direct.
$99 ea. for same GM hinge from Ricks.
$35 ea. for imports from GroundUp. $95 ea. for GM hinge from GroundUp.
Get the GM made hinges.
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Nov 17th, 06, 02:19 PM
Get the GM hinges you will be glad you did , and just use your old but still good hood springs .
Mark .
Old Nov 17th, 06, 02:45 PM
HwyStarJoe's Avatar
I totally understand about the "This is not for a "cost is no object" restoration" feelings when it comes to spending money on your Camaro.
Believe me, I do. But some things are better off with good quality parts.
It's taken me 7 years to get as far as I have, and it's not for a lack of time, if you get my drift.
SEMA ACTION NETWORK
Old Nov 17th, 06, 05:16 PM
Fred Ficarra Fred Ficarra is offline
Fred
My Gawd! Get the GM's! And try to score the 396 springs. Mine are. I lube them once every ten years or so with LPS3. Just like new. No wear. Caution; with my set-up when opening the hood, have your other hand ready to CATCH IT! It flies up so fast that it's scary. I'm not brave enough to let hood go just to see what happens. And a remote hood release is out of the question.
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's spool, ducted hood, Endura, spoilers.
TH400 (CX) GV OD, 8 track still on console and best et 10.862, 124.24mph 1.478 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
Old Nov 17th, 06, 06:10 PM
James
So you have tried the repro hinges and they fit poorly?
Old Nov 17th, 06, 06:13 PM
James
Thanks for the parts sources, much better than Classic at $112 each
Old Nov 17th, 06, 08:20 PM
Rich
ragtop,
you could make them fit but that's not what we were looking for. went thru 2 sets, year one and classic. repros were light weight and poorly made. hey, but they looked pretty!
comparing the repros to the gm.......
do you wanna buy nice fresh clean oats or are you willing to settle for the oats that have been thru the horse?
Old Nov 18th, 06, 09:58 AM
Unreal Unreal is offline
Gary
There are two sets of springs, one for the SS hood (350 and 396), and one for both the cowl hood and standard hood. Sounds like you have the springs for the heavier SS hood, on the lighter cowl or standard.
Old Nov 18th, 06, 10:41 AM
Fred
Unreal, I guess you're talking to me. My hinge setup came with the car. Original equipment. I always thought the strong springs came with the BB. Just assuming,,,
Old Nov 18th, 06, 12:00 PM
James
Fred, count the coils. 26 for flat and cowl hoods, 28 for the heavier SS hood.
Did you put the cowl hood on? if so you should change to the 26 coil springs.
Old Nov 18th, 06, 12:06 PM
James
Ok, looks like I should get the GM hinges from GM parts direct.
I don't have a problem using aftermarket or non original parts as long as the fit and function are there.
As an engineer, it's frustrating to me that 40 years after the original part was made, new reproduction part quality is lower, even with modern technology and quality standards.
Similar Threads
Cowl Hood Not lining Up Ken Miele Body Shop 15 Apr 11th, 06 01:25 PM
Door adjustment jsouthco68camaro Body Shop 9 Mar 7th, 05 05:46 AM
Door Hinge & Remount Question Dwight's Z/28 Body Shop 3 Oct 9th, 03 02:26 PM
1968 door alignment Steve W Body Shop 5 Sep 9th, 03 04:15 PM
Door adjustment Unreal Body Shop 7 Mar 2nd, 03 01:54 PM
