Body Shop Paint & Body Forum
Old Dec 14th, 99, 04:30 PM
Shawn Shawn is offline
Default
I'm re-doing my interior, and in the process removed the kick panels. The kick panel vents are sealed from behind with massive globs of Dum Dum putty. Mine was pretty gross, so I pulled it all off and chucked it. Anybody know where to find more putty, or a suitable replacement for it? Some places have suggested using seam sealer.
Shawn Peterson
1969 Z28, 406SB
[This message has been edited by Shawn (edited 12-15-99).]
Old Dec 15th, 99, 03:00 PM
CHRIS SILVA CHRIS SILVA is offline
Tech Team
Default
Hi there shawn the product you are talking about is made by 3m and is called strip calking but to get the original stuff use buytal {spelling ?} tape they sell it in rolls I would get 1/4 inch it is just what they used in the 60's.It may be hard to get depending where you are.
Old Dec 15th, 99, 03:51 PM
CarlC CarlC is offline
Default
Chris - When I dis-assembled my '68 it did not have butyl as a sealant for either kick panel. It did have the dum-dum type putty that Shawn is iquiring about. My car does have A/C so maybe that has an effect. Any thoughts?
Shawn - I ended up going to Home Depot and going into the section that has the self-adhesive foam tape for refrigerators. In the same section they had a Frost King dum-dum type product that was used for sealing seams around windows. It is a ribbon of sealant that will separate into 1/8" strips. I just rolled it into the necessary size. It releases easily (I think I took everything of my car at least twice during restoration!) but seals well. It also works very well for sealing the stainless weatherstripping retainer (located above the side windows)to the body. Shouldn't cost more than $5.
Old Dec 15th, 99, 07:35 PM
Austin Austin is offline
Default
3M does also have a "dum dum" type sealer let me know if you want the 3M part number I have some at work and can post the part number if anyone would like it.
Old Dec 17th, 99, 05:37 AM
Tech Team
Default
CarlC you are right. I was thinking of something else,3M Strip-Calk part# -08578 [black] is the right stuff to use.Don't use seam sealer! The cost of this stuff is 6.25 a box.
[This message has been edited by CHRIS SILVA (edited 12-17-99).]
