 Ground Up Restorations
Second Generation 1970-1981
Old Nov 23rd, 06, 09:57 PM
Evinrude Evinrude is offline
Default 1980 Rear tail panel
My 14 Year old son and I are fixing up a 1980 Camaro. The rear tail panel is rusted down low and around the bumper mounting points. I bought a replacement panel. There is another inner panel that goes betwwn the lower tail panel and the gas tank. Can anyone tell me where I can find a replacement or should we leave it out?
Old Nov 24th, 06, 05:31 AM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Default Re: 1980 Rear tail panel
Evinrude, Welcome to Team Camaro!
I'm going to move this down to the Second Generation catagory a little further down the main page.
...'69 Camaro
http://streetmachinesofrochester.com/main.htm
Old Dec 13th, 06, 11:35 PM
earthquake68 earthquake68 is offline
Tech Team
Alan
Best bet is to search the local yards. A junk section or self-fabrication may be the only ways to go. The factory never put anything in these cars it didn't need. If they could save a dollar a car, that ment hundreds of thousands at the end of the day. If it had it, it needs it, put it back.
Speed's expensive, how fast do you want to go?
Old Dec 25th, 06, 01:26 PM
NEALS79Z NEALS79Z is offline
NEAL STURGES
AS OF SEVERAL YEARS AGO WHEN I MYSELF HAD BOUGHT A CAR WITH THIS SAME ISSUE,NO ONE WAS MAKING THIS PART. EVEN GOODMARK' NOW THE PROBLEM WITH THIS ALSO IS THE PANEL IS SPOT WELDED TO EVERYTHING, A VERY EXTENSIVE OPERATION OF CAREFUL CUTTING AND DRILLING IS REQUIRED TO DO THIS,IF THE FLOOR ISNT BAD WHERE THE LEAF SPRINGS MOUNT AND THE TRUNK IS GOOD.YOU COULD TRIM THE TOP EDGE EVEN WITH THE TRUNK FLOOR AND DO THIS. MAKE SURE YOU REMOVE THE GAS TANK. ALSO SOMEONE WITH A FAIR AMOUNT OF SHEET METAL BACK GROUND COULD MAKE SECTIONS TO WELD IN, OR FIND A CAR THAT HAS A NICE PANEL, DEPENDS HOW BAD YOU WANT TO SAVE THIS CAR, AND HOW LONG YOU WANT IT TO LAST THE TEST OF TIME.MANY 2ND GENS HAVE THIS AREA RUSTED, LOOK AGAIN FOR SOMEONE WHO MAYBE HAS THIS PART AVAILABLE AFTERMARKET.
Similar Threads
tail panel welds and seam sealer 69Rfine Restoration Corner 2 Jun 8th, 06 07:39 PM
1969 firebird tail light panel aplusbiz Restoration Corner 0 May 4th, 06 11:37 AM
69 rear tail panel fit Illinois69SS Body Shop 2 Oct 19th, 05 10:48 AM
Tail panel replacement ? ebd Body Shop 7 Apr 2nd, 05 07:59 PM
1967 L78 Rear Tail Panel color spistols Body Shop 0 Oct 25th, 03 07:40 AM
