Pro Touring Todays performance with classic style
Old Nov 29th, 06, 10:49 AM
Old Man Old Man is offline
Mark
Default 572 CI CBB in a 69 Z28?
I'm still in the planning stages of building a PT 69 Z28. I want to go with a 572 CID crate motor, does anyone know if a 572 will even fit in a 69 Z28? If so will it require major modifications to fit it in there? TIA,
Old Nov 29th, 06, 11:11 AM
Vegas69 Vegas69 is online now
Todd
Default Re: 572 CI CBB in a 69 Z28?
From what I have read you will need atleast the 2" cowl hood and custom headers. Not sure the normal big block brackets bolt up either. I think I am going with a 540 for standard deck height. You can get a 540 built with alot more horsepower cheaper. I like the sound of 572 I have to admit.
Old Nov 29th, 06, 01:08 PM
Mark
Initially I was leaning towards a 468 with N20 but I don't want to mess with nitrous on this car, I want to try and keep it as simple as possible.
Old Nov 29th, 06, 05:36 PM
jks67SS396 jks67SS396 is offline
Jeff
im building a 540 for my 67. There are guys on Chevelles.com running lots of hi-po 540s that make way more than 620 and 720 hp on pump gas.
My own 540 (pump gas, street car) will hopefully make around 750. Its pretty easy to get a ton of power out of these bigger cube big blocks. for a lot less than the 572 and with a 9.8" deck...
1967 SS 396, M20.
now a 10.4:1 540, AFR 315 heads, UDHarold SR Cam with a Tremec TKO
Old Nov 29th, 06, 05:44 PM
Todd
What are you doing to your 67 chassis to strenghten it from twisting with 750 horse? I am looking at options right now for my build.
Old Nov 29th, 06, 05:51 PM
Mark
I have a 99 T/A that makes 500 RWHP N/A, 750 RWHP on the bottle and runs low 9's in the quater which is plenty fast for me so I wanted to keep the motor for the 69 fairly close to stock and run a big cubed motor N/A for street driving and maybe an occasional trip to the track. I'm not familiar with a 540 motor could you please give me a brief run down on the specs, thanks.
Old Nov 29th, 06, 10:13 PM
cody cody is offline
4.5" bore x 4.25" stroke, standard deck.
71 formula firebird, 468; AFR rectangle port, 11-1 compression, Isky Solid Roller 290/294,...620HP, Viper T56 six speed, 19" CCW rims, Hydroboost, C5 corvette brakes.. currently being built(almost done)http://www.formula454.com
Old Nov 30th, 06, 03:20 PM
Jeff
weld in subframe connectors, caltracs, solid body bushings, prothane suspension bushings. ive got 275 micky thompson drag radials waiting to go on. rear end is a 9" 3.70 detroit locker, 35 spline, 1350 yoke. Tranny is a little tko 5 speed with mcleod street twin clutch. may change the clutch out to make sure thats the weekest point (compared to tranny) if i hook it up.
1967 SS 396, M20.
Old Nov 30th, 06, 03:23 PM
Jeff
9.8" Dart Big M block with Billet caps
Callies Dragonslayer crank
Manley H Beams
Mahle pistons 10.5:1
AFR heads.. either 325 cc with CNC option or 335 fully CNC head.. may mill to up the CR
solid roller in the mid 260s @ 050 and decent lift (still specing that out).
I want it to look like my stock 396/325 motor
check out chevelles.com in the performance section. tons of 540s over there.
1967 SS 396, M20.
Old Dec 1st, 06, 08:07 AM
Mark
Thanks for the info, I'll check it out.
Manley H Beams
Old Dec 2nd, 06, 12:31 PM
pdq67 pdq67 is offline
Banned
A 571" standard deck engine can be made too!
4.56" b x 4.375" s = 571"..
I would use a 6.450" long custom rod and needed zero deck height pistons along with a STOCK, 9.8" tall deck height so as long a rod as possible can be ran..
pdq67
Old Dec 2nd, 06, 08:55 PM
69RS-Yenko 69RS-Yenko is offline
Cool Re: 572 CI CBB in a 69 Z28?
I'm running a 540 4 spd in a 69 RS/SS PT car I'm making right at 635hp & 575 RWHP with 600 Tq. I have to say I love the tq, your going to have to beef the chassie big time to hold all the tq a 540 will make. I've added welded sub frame connectors Lowered the car to about 5 inches rocker clearance which helps plant the power. I'm going to try to use comp slide a links if I can add them without dragging them.But with a 285/50/17 drag radial it's kind of like dry pavement turns to ice real quick, so if your going to run a stroker big block anything be ready for a wild ride.
Old Jan 25th, 07, 11:48 AM
mjpell mjpell is offline
You may want to rethink the Detroit Locker behind the manual transmission.
I ended up replacing mine with a spool. The problem I had, which is supposedly common, is that during a hard/fast shift, the pressure is released allowing the locker to disengage. Then when you dump the clutch. the Locker doesn't always have time to properly re-engage, and you get a 1-wheel-peel. I experienced this many times, especially at the track.
I'm happier with the spool.
And right on about the twin disc. That's about the only thing that we've seen break a TKO.
Mike ('69 Prostreet Chevelle with TKO-600)
Team Chevelle Gold Member, #178: '69 Malibu Pro-Street
'69 Camaro
'65 GTO, 4sp, 400ci, console, bucket seats
http://www.prostreetcar.com
Similar Threads
69 restored Z28 - might need to sell smith69z What's it worth? 22 Feb 1st, 07 02:49 AM
Exhaust system for a 69 Z28??? W.A.C Performance 8 Oct 2nd, 06 08:01 PM
Swapping Guages on a 69 z28 jokernj1 Electrical & Wiring 1 May 19th, 06 06:57 PM
Finally Found a 69 Z28 in Manila csn69ss Tag Team 29 Dec 14th, 05 12:08 AM
09c 69 Z28 Lukes 69 z28 Tag Team 7 Dec 4th, 05 10:42 PM
