Type II GM PS pump - Team Camaro Tech
Thread Tools Display Modes
Old Dec 9th, 06, 08:20 AM
jcdubs's Avatar
jcdubs jcdubs is offline
Jeff
Default Type II GM PS pump
Anyone have any pics of the type II GM P/S pump with the remote reservoir on there small block. I want to keep my power steering, and was thinking it may be better in a perfomance application then the old style saginaw unit. Mine tends to spit out some fluid when up in the RPM range.
Jeff
My Black 67 - 400 Dart Little"M", SRP 10.2:1, 4340 Scat rotating Assy, Solid Roller, AFR 210 Eliminators, Jesel shaft rockers,Super vic, Prosystems 847CFM, Tko600, 12 bolt 4:10 Eaton posi W/ Strange Hy-Tuf race axles and eliminators.
Best E.T. June 6 09 (11.96 @ 118.06) N/A
71 SS 396 Classic Copper 4 Spd
Old Dec 10th, 06, 04:03 PM
davidpozzi davidpozzi is offline
David Pozzi
Default Re: Type II GM PS pump
If it's coming out of the cap to reservoir seal area, there is a later cap with rubber baffle attached you can try. It's used on 80's pickup trucks. The plastic dipstick is necked down and the rubber flap surrounds it.
Sweet sells a type II pump that is all set up for long waterpump pulley sets. It has a nice aluminum mount and aluminum pulley.
David
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
Old Dec 11th, 06, 05:20 AM
jcdubs's Avatar
Jeff
Thanks David, I will check into it.
Jeff
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Brakes, Suspension & Steering      Current Topic: Type II GM PS pump
Location
Location
First Name
Human Verification
Similar Threads
Fuel pump electric type knightmoose Camaro Tech 3 Aug 14th, 06 08:27 PM
dumb question about clocking Mech Fuel Pump Brad74 Engine 6 Mar 21st, 06 08:10 PM
Running with the stock intank fuel pump... RegaMaro Performance 0 Mar 8th, 06 10:25 PM
Fuel Line and Pump Upgrade eville Performance 6 Feb 14th, 06 06:20 AM
Power Steering / Belt Alignment Problem kgaffney Tech 2000 17 Jul 9th, 01 05:36 PM
