1969 Camaro Leaf spring Bushings - Team Camaro Tech
Old Dec 11th, 06, 02:52 PM
onewickedcamaro onewickedcamaro is offline
Tech Team
Cool 1969 Camaro Leaf spring Bushings
I am replacing my bushings on my leaf springs. I noticed that the nut bottoms out before the bushing are tight against the shackles. Is this the way it should work or do I have the wrong bolts?
Old Dec 11th, 06, 03:44 PM
DOUG G DOUG G is offline
RedЯuM
Default Re: 1969 Camaro Leaf spring Bushings
Thats right.
The bolts/nuts are made to bottom out before you put it in a bind and the springs don't move.
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Dec 12th, 06, 03:48 AM
tgifford5 tgifford5 is offline
Team Member
Ted
Are you using after market shackles? I just replaced my rear spring bushings. And at first I used some aftermarket shackles from JCW. They were way loose and so I checked on the length of the new vs. the old bolts. The new ones were longer. So I ended up cleaning up my old shackles and bolts and reused them. Did you use rubber or poly bushings? The rubber bushings had a larger head thickness, therefore needing the longer bolt.
Similar Threads
Installing Hotchkis rear leaf spring bushings DHH Brakes, Suspension & Steering 6 Aug 7th, 07 02:47 PM
Coil Springs Help ? rookie68camaro Brakes, Suspension & Steering 32 Dec 13th, 06 07:15 AM
MAILBAG: Readers give reactions on Camaro OverAnxious Fifth Generation 0 May 18th, 06 07:07 AM
2005 SuperCar Reunion & Outdoor MuscleCar Show Sept. 2 & 3 CamarosRus Team Camaro Cruiz-Ins 19 Sep 7th, 05 06:53 PM
Question about Hotchkis rear leaf front eye bushings Rocketrod Brakes, Suspension & Steering 3 Mar 19th, 05 09:56 AM
