| Team Camaro Tech Current Topic: Alternator Upgrade confusion | ||
| Electrical & Wiring Troubleshooting electrical. |
Hopfully someone here at Team Camaro can chim in
Has anyone here with a 1969 Camaro successfully upgraded their stock passenger side engine mounted GM Alternator and external voltage regulator to a 3 wire internal voltage regulated 105A CS130 Alternator?, utilizing their original long water pump mounting brackets? If so, which CS130 Alternator was used? And what bracketing modifications were necessary if the origional bracketing could not be used? Thanks in advance.
Kurt 1969RS 10yrs into it. 383CID Lives 200R4 Trans, 3:42 Posi 12 Bolt ReadyCold ones in the fridge. Dam, there gone. BRB ![]() Getting closer to my goal. ![]() http://home.comcast.net/~aradrs/site/ |
| Sponsored Links | ||
Advertisement | ||
I upgraded mine over the years. It was originally a 37 amp. But during the interim I installed a Moroso aluminum water pump and trashed the original brackets. (mistake) Then Edelbrock came out with aluminum stock-style reproductions. But by that time I was only using the pivot bolt. To increase the alternator output I went with a Summit 100amp kit. It works well. My most recent change was to relegate the original deep grove pulley to the 'memory parts' box. The new small pulley is deep and 'machined' too, but smaller in diameter so that it charges at idle. WORKS! (Charging is a challenge because of the electronic stuff I've added over the years) The top bracket is home made.
Oh, 3 wire INTERNAL regulated??? How? Why? Never heard of 'em. But hey, I live in the wild west.
One owner 69 Camaro,(yep, bought it new )RS SS Hugger Orange, L88, 4:10's spool, ducted hood, Endura, spoilers. TH400 (CX) GV OD, 8 track still on console and best et 10.862, 124.24mph 1.478 60' All with 1960's stuff. (except tires and converter) + MT Super Scavenger headers. 1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too. ![]() http://epitomesrebuild.com/ |
| Sponsored Links | |
Advertisement | |
Similar Threads
| more pulley confusion | 68resurrection | Engine | 3 | Nov 27th, 06 09:30 PM |
| e-bay ad a little confusion on the year... | nikkisdad | Bench Racing | 2 | Oct 18th, 06 09:27 AM |
| Torque converter confusion | rebel04 | Transmission & Driveline | 0 | Sep 21st, 06 05:30 PM |
| courtesy light confusion | utility5 | Electrical & Wiring | 0 | Jan 14th, 06 05:21 PM |
| Leaf spring confusion (convertible) | DjD | Tag Team | 1 | Jan 30th, 02 10:09 AM |
