| Team Camaro Tech Current Topic: 94 rear end? | ||
Will a '94 camaro rear end bolt into a first gen camaro?
| Sponsored Links | ||
Advertisement | ||
No. Find a 10.5 from a Nova.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1 |
Not even close. It is completely different.
'69 RS/SS396 pro street/427/4spd/9" http://www.camaros.net/showroom/show...00&ppuser=1922 |
Thanks Gentelmen.
I meant to say an 8.5 10-bolt. Sorry.
Still won't work!
If the 8.5 is from a Nova or other X body then it will bolt in. If it is from a second gen Camaro then it won't bolt in.
Whats different in a gen II rear end?
Graham 67 Resto 383 on 20's
It is 1 inch wider and the spring perches are almost 3 inches too far apart.
It will fit, because I have one on my 67, you have to cut the perches and weld new ones on not to mention cut about 2" off the driveshaft
| Sponsored Links | |
Advertisement | |
Similar Threads
| Rear end clean up | magic0125 | Transmission & Driveline | 10 | Nov 11th, 06 06:21 PM |
| Standard rear end for 2001 Camaro Z28 | djrlitlbit | Fourth Generation | 2 | Nov 5th, 06 09:21 PM |
| '67 rear end swap - posi + discs | Strick | Brakes, Suspension & Steering | 0 | Oct 31st, 06 03:02 PM |
| Another rear end numbers post | dcordle | Transmission & Driveline | 5 | Jun 7th, 06 03:33 PM |
| Rear End Rebuild? | foooz | Transmission & Driveline | 3 | Nov 25th, 05 07:05 AM |
