| Team Camaro Tech Current Topic: Trans replacement for 94 Z28 | ||
hey guys. Im looking to replace/rebuild my automatic transmission
in my 94 Z28. What would be the best idea? Replace or rebuild? If replacing is the way, what fits and whats best for the money....Looking for street and strip capabilities. Thanks in advance.
| Sponsored Links | ||
Advertisement | ||
Many people here will say 2004r, but you would need a new driveshaft. I would find a good transmission builder in your area and have him build you a good 700r4.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1 |
The transmission in your car is a 4l60E. This is a good tranny. You can either price your local shops for a rebuild to your specs or get a new one. There are more than a few "built" 4l60E's on ebay if you wish to go that route. The 4L is a 700R4 that is improved. Not only can you electronically set the shift points, but it is also stronger and less prone to overheat. Unless you are looking for big power, just rebuild your original tranny as it will hold up fine to upwards of 400 hp if not beat up. This avenue is the easiest and most cost affective.
the learning curve is....expensive
| Sponsored Links | |
Advertisement | |
Similar Threads
| Muncie trans decode help needed | South Side Goons & Hitmen | Transmission & Driveline | 10 | Oct 30th, 06 02:42 PM |
| X77 Z28 without power brakes? | jhilts | Camaro Tech | 2 | Feb 20th, 06 10:13 AM |
| BTO trans x-member/trans mount prob | GunnerV | Transmission & Driveline | 9 | Sep 28th, 05 06:29 PM |
| unidentifed trans | brandnewbad | Transmission & Driveline | 5 | Jul 3rd, 05 06:16 AM |
| Trans mount replacement help | joe clance | Tech 2000 | 1 | Mar 31st, 01 04:42 PM |
