Frame rail replacement-Help! - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Oct 9th, 02, 03:43 PM
Grant Grant is offline
Tech Team
Default
I plan to replace the full floors on my 69 convert soon. I feel pretty confident that I can handle the floors myself + save a few bucks along the way. I've learned a lot from working on these cars and really appreciate this site and all the posted information here. It's been a BIG help. I have two problems that I have to get fixed before I replace the floors. 1) Both rear floor supports(where leaf spring brackets bolt to) need to be replaced. I know they are not in repro at this time.Drivers side is the worst-this side will also need the last 1 ft of frame rail replaced as well. Are there replacement rails available that go all the way to the rear floor support? If so I cannot find them-only the shorter ones. Can these pieces be fabricated or should I try and find from a donor car and have them welded in? Or, would it be wiser to replace the floors first and then tackle the floor supports and frame rail?What do the experts out there think? I want to repair this stuff first before I do anything else on the car. Thanks.
Old Oct 10th, 02, 12:36 AM
Toby Keen Toby Keen is offline
Default
I believe Competition Engineering offers what they call replacement rear frame rails for First Generation Camaros. I've never used them so I can't say anything about how they fit.
Old Oct 10th, 02, 06:39 AM
Jim McGregor Jim McGregor is offline
Default
Here is the website for CompEng http://competitionengineering.com/ca...?CatCode=11005
This will take you to the exact page. Looks like a considerable amount of welding will be required.
Old Oct 10th, 02, 07:24 AM
bretcopsey bretcopsey is offline
Default
....but those CE rails mount inboard of the factory location to move the springs inboard. They don't "flair out" like the stock ones do, and you will have to modify the fuel tank to use them.
Bret Copsey
'68 Camaro base coupe
'92 Caprice Wagon
'99 Venture Van
my 68 camaro
Old Oct 10th, 02, 08:24 AM
choptop's Avatar
choptop choptop is offline
Scott
Default
Rick's has some "slip in" rails that fit inside the old ones. They are 45" in length (measured from the shackle mounting point) so i don't think they have the frame section that you need the most. Might be worth a shot if you call Rick's and ask...otherwise you will need a donor car or try to fab some up yourself.
Good Luck!
See my '68 RS/ZZ4
Old Oct 10th, 02, 12:14 PM
Tech Team
Default
Thanks for the reponses you guys. I did look at the CE frame rail and agree with Bret-they dont seem to be for a stock application which is what I need. Choptop, thanks for the tip about Rick's. I'll check it out but i'll probably end up having to get from a donor car which will be a pain is the @!#$. Oh well, I would rather fix this then drive a KIA! Heh Heh....
Old Oct 10th, 02, 02:10 PM
choptop's Avatar
Scott
Default
I wonder if you could make a template from another car and get a local metal fabricator to make you a custom piece? Or maybe it is possible to form the piece you need from some of the replacements?
Might be cost effective, you never know!
See my '68 RS/ZZ4
Old Oct 10th, 02, 04:05 PM
Tech Team
Default
I suppose. I'll see what I can come up with. Now that I think about it, i'll probably have to have somebody fab the pieces I need. Even if I were to locate a donor car i'm not going to have my air tools available to remove the parts anyway. You would think that with all the other OEM sheetmetal available for these cars that these pieces would be available as well.
Old Oct 10th, 02, 06:03 PM
Oramac68 Oramac68 is offline
Default
grant, make sure you support the car in a few places underneath(side to side) and either buy bolt in door braces or weld straps across the door openings (front to rear) or the body will twist and sag.
Old Oct 11th, 02, 05:55 AM
Tech Team
Default
Oramac68, thanks for the info..yeah i'll put braces in for the doors and probably support the car with 4 x4 's under the rockers as well as jack stands up front. The car is complete including front clip and rear so it should be enough and not sag. I'll get it level before I put the floor in and only do one side at a time. I'm dreading fixing the drivers side frame rail and floor supports..that's going to be the hard part of this whole thing.
  #11
Old Oct 11th, 02, 08:20 AM
Default
For what it's worth Grant, I repaired the section you have the problem with on one side myself. From the brace/bracket uner the seat to just after the first up bend. I used thicker sheet metal and made it up in three pieces. I put a cross brace inside and welded the whole thing up. It looks as good (actually better) than the original, and is at least as strong. It was just a matter of taking my time. Ensure that you mark the location of the e-brake cable bracket.
  #12
Old Oct 11th, 02, 11:23 AM
Tech Team
Default
Jim, thanks for the info. How did you form the floor support piece? Did you copy it from the other side? Did you make a template? Do you have a picture I could look at?
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Frame rail replacement-Help!
Location
Location
First Name
Human Verification
