383 Block Notching - Team Camaro Tech
Thread Tools Display Modes
Old Dec 24th, 06, 04:13 PM
Countryside_Cafe Countryside_Cafe is offline
Default 383 Block Notching
Anyone know where a I can find DETAILED documentation on exactly how to properly notch a 350 block for a 383 stroker kit and crankshaft?
Old Dec 24th, 06, 04:56 PM
kausboy kausboy is offline
Tom
Default Re: 383 Block Notching
I thought to build a 383 you used a 400 crank with the mains turned to fit in a 350 block and used 350 rods with "short" pistons (pistons with shorter skirts). There are "kits" available now that make it a snap!
I don't remember "notching" the block when I built mine -I did however use the wrong rods the first time and the piston skirts hit the counterweights!!! (That's embarassing )
Old Dec 24th, 06, 05:12 PM
Eric68 Eric68 is offline
Eric
There is no real detailed info on notching a 350 block because all the blocks and stroker kits are a llittle different -- all have to be checked. Maybe there is a book somewhere that tells you how, but the bottom line is you need to make sure there is at least .050" clearance between all your moving parts (bearings are obviously not .050" -- they are more like .0025" rod and .003" main).
1. Crank counterweights to oil pan rails
2. Connecting rod bolts to oil pan rails.
3. Connecting rod bolts to cam lobes (especially cylinders 1,2,5,6).
4. Piston skirts to crank counterweights.
I made a go/no-go gauge from a piece of coat hanger that I flattened to .050" on the end. Then the coat hanger wire can be bent to reach whatever tight spot I need to check.
E85 racer and E85 carb builder
www.horsepowerinnovations.com
68 Camaro, E85 powered 427" small block. 9.96 @ 133 MPH, 1.319 sixty foot on motor. 5.92 eighth @ 116 with a 1.42 sixty breaking beams with back tire on the bottle
Old Dec 24th, 06, 06:08 PM
camaroman7d camaroman7d is offline
Royce
Ditto what Eric said.
Royce (NO XQSSS) Bradley
www.facebook.com/driveyourjunk
http://www.youtube.com/watch?v=DSLsGgDjFXE
(brief sound/video clip, 3 1/2" exhaust through Borla Sportsman mufflers)
Old Dec 24th, 06, 06:22 PM
JimM JimM is offline
Jim
Here's a pic of the notching required when I stroked my 327.
Old Dec 31st, 06, 02:50 AM
rolling-robert's Avatar
rolling-robert rolling-robert is offline
robert
thats a lot of notching! i just had some minor notching to do when converting my 350 to 383
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
Old Dec 31st, 06, 08:37 AM
onovakind67 onovakind67 is online now
It must be a Mexican block. Bonus Notches, Señor...
Old Dec 31st, 06, 09:43 AM
pdq67 pdq67 is offline
Banned
Guys,
Fwfw, Jim's pic is an excellent shot at what a "round-bottom" block look's like whenever I start mouthing off about round-bottom 283 blocks..
pdq67
Old Dec 31st, 06, 09:54 AM
Jim
fyi, that is my original EE code 327 block, cast and assembled in 1968, and stamped with my verts vin by the Norwood assembly plant in early march of 1968
Old Jan 2nd, 07, 12:27 PM
gui67 gui67 is offline
Guillaume
If I can help, here are pictures of my block I am currently building, it's a 327 small journal from 67:
I am building a 383 with a crank from speed-o-motive.
Regards
Guillaume
Team Camaro Tech > All Generations > Performance      Current Topic: 383 Block Notching
Location
Location
First Name
Human Verification
Similar Threads
Small Block or Big Block PDW HOTRODS Performance 25 Dec 19th, 05 07:21 PM
383 stroker??? Prostreetcamaro1 Performance 18 Oct 26th, 05 07:31 AM
Home Block Notching luccamaro68 Performance 5 Mar 29th, 05 02:48 PM
May purchase new ZZ4 block for 383 tommyg Performance 13 Nov 29th, 04 10:46 AM
Block Plate, clutch fork pivot adjustment Luke68ss Transmission & Driveline 14 Jan 21st, 04 07:24 AM
