Heads - Team Camaro Tech
Old Dec 28th, 06, 10:26 PM
mbrown mbrown is offline
Marcus
Default Heads
Hi all,
So I'm at the stage in my 383 build up, putting the heads on. Quick question. As I read the manual on how to build a chevy small block. It states that put the heads on the correct side of the block. How can I tell which is which. One head has a stamp of 10 and the other is 9. I think that 10 goes on the even side and 9 goes on the odd side. But I wanted to double check with you experts. This is my frist complete engine rebuild.
Thanks for the help. any tips on installing would be nice too.
Old Dec 29th, 06, 05:24 AM
onovakind67 onovakind67 is offline
Default Re: Heads
Unless they have been machined or modified specifically for the odd or even side you can use either head on either side.
Old Dec 29th, 06, 05:34 AM
Larger Dave Larger Dave is offline
Dave
Cool Re: Heads
All you have to match is the intake ports to the lifter valley side and exhaust to the headers
Your worry will be setting the heads down without disturbing the head gasket the first time (never a problem with head studs), if using cast iron heads. Don't want them wandering around looking for the two locator pins on each end of the block.
Good luck and take pride in your accomplishments.
Larger Dave
Old Dec 29th, 06, 02:28 PM
DOUG G DOUG G is online now
RedЯuM
Default Re: Heads
Most if not all new heads are drilled and tapped at both ends so it wouldn't matter. Old heads (some) were a different story.
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Dec 29th, 06, 02:32 PM
dawg's Avatar
dawg dawg is offline
Harry
Default Re: Heads
just make sure the assesory bolt holes are facing the right side.
Dawgs 69
406 stroker
us navy retired
http://www.northeastf-bodyassn.com/
Old Dec 29th, 06, 06:10 PM
Marcus
Default Re: Heads
when you say the accessory bolt hole on the right side you mean the little hump on the oil pan side right?
Old Dec 29th, 06, 06:21 PM
zdld17 zdld17 is offline
Don
Default Re: Heads
Means the three 3/8's holes drilled on the end of head , to attach any accessories like alt , ac comp backets, etc. Usually they are on either end. Usually, depending on head manufacture.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Dec 29th, 06, 06:28 PM
pdq67 pdq67 is offline
Banned
Default Re: Heads
Ditto!!
Ends of head!!
pdq67
Similar Threads
BBC Heads selection help jaslamp Engine 3 Sep 10th, 06 08:14 AM
Heads, i need to choose. Ryan's 64 Engine 9 Sep 9th, 06 02:02 PM
406 needs new heads jackr Performance 9 Jun 7th, 06 10:34 PM
Pro Action Heads my69gofast Performance 25 Feb 22nd, 03 07:33 AM
truck heads vs. hump heads toolman Tech 2000 3 Nov 1st, 00 08:34 PM
