Third Generation 1982-1992
Old Dec 29th, 06, 11:18 AM
shoe shoe is offline
Jeff
Default Headers for a TPI 305? Need advice
68 Camaro, 305 TPI with all of the smog stuff out of an 85 IROC. Need expert opinions on removing stock exhaust and just putting regular headers on it (no EGR tubes).
First, do I need the tubes and smog pump crap?
Second, will removing all of that and putting headers on improve any performance?
Third, any idea how to hook up the heater to a TPI setup? Only 1 hose is hooked up to the intake, not sure where the 2 hoses should really go.
Thank You!
-shoe
Old Dec 29th, 06, 03:34 PM
dsherw00d dsherw00d is offline
Dan
Default Re: Headers for a TPI 305? Need advice
If your in CA, then the hooker 2055s should work. I have them on my 88. They have the smog tubes and stuff to meet all the polution requirements. They come with the cross pipe. They bolted up pretty easily, but you will have to adapt some of the mounts that connected the the cast iron flanges. They can also be a pain to get in. Look at http://thirdgen.org and they have tons of info - including install help. This is the place to also look for your other answers.
-Dan
http://www.thesherwoodgang.com/cars/
Old Dec 29th, 06, 08:51 PM
67 Plum's Avatar
67 Plum 67 Plum is offline
Chad
Look at the thread you started in engine section.
Similar Threads
305 tpi on 350 snapperhead Camaro Tech 25 Mar 2nd, 06 06:56 PM
87 iroc 305 tpi mis-fire problem purityxknight Troubleshooting 8 Dec 25th, 05 05:46 PM
choice of headers blue67 Performance 10 Sep 12th, 05 09:29 PM
69 BB Headers and exhaust, HELP Hawaii5-0 Engine 3 Mar 14th, 05 06:34 PM
