What Rear End Fluid with Eaton Posi? - Team Camaro Tech
Thread Tools Display Modes
Old Dec 31st, 06, 10:45 PM
Black Z Black Z is offline
Question What Rear End Fluid with Eaton Posi?
What brand and weight rear end fluid should I use with a new eaton posi in my 1969 camaro 10 bolt? Also what limited slip additive should I use? Thanks
Old Dec 31st, 06, 11:17 PM
Straight-line-69 Straight-line-69 is offline
Default Re: What Rear End Fluid with Eaton Posi?
Eaton "strongly recommends" conventional/mineral lubes plus the GM "limited slip" additive (GM part number 10522358) for use with their posi's. Valvoline 80-90w works for me.
Old Jan 1st, 07, 12:50 AM
By conventional/mineral lubes does that mean no synthetic oil? What weight do they recommend, it does not say on their website?
Old Jan 1st, 07, 08:07 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Alot of us use Amsoil Synthetic Gear lube 75w90, it has the additive built into the oil itself. While Eaton shys away from recommending Syns, (they cant seem to find the time to test their units in all the variety of lubes out there), Amsoil does warrant their product in the Eaton gears. It will run MUCH cooler and give better mileage than a dino oil. Many rear end rebuilders highly recommend the Syns.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos of my Camaro for viewing
Old Jan 1st, 07, 08:53 AM
big gear head big gear head is offline
Freddie
I use Amsoil 75W90 Severe Gear synthetic oil in them. No problems in 10 years. GM has been using synthetic oil with Eaton differentials for around 8 years now. 2 quarts will usually fill it. Otherwise use 80W90 petroleum oil with GM or Ford additive.
Old Jan 1st, 07, 09:18 AM
Jonesy's Avatar
Jonesy Jonesy is offline
Mike
I'm with Click and BGH. AMSOIL is what I put in mine without any problems also.
Team Camaro Gold Member #14
1967 Camaro RS/z28 - one of 602 made - SOLD
1969 Camaro RS/SS L48 4 speed
1974 Camaro LT-Z/28 4 speed 33K orig miles
1979 Camaro Z/28 36K orig miles
1984 Camaro z/28 LG4 auto
Old Jan 1st, 07, 09:52 AM
rogue68 rogue68 is offline
I run the conventional + additive w/ Eaton and works great. Never even thought about synthetic. I wonder if there are any issues switching between the two?
1968, M20 PDB 12posi-3.73 400SB (KB125 5.7"r AFR195 CS286H 750cfm-mech-annular_boost 10.2CR AirGap 6AL)
Old Jan 1st, 07, 10:12 AM
What about for the initial 500 mile breakin period? Would it be like an engine breakin period where it is recommended to use only conventional oil, no systhetics? Do all of the amsoil oils have the limited slip additive in it already?
Old Jan 1st, 07, 10:31 AM
ept000 ept000 is offline
Eric
I used Redline synthetic and it chattered like crazy. Changed to Valvoline and the GM additive and it's perfect now.
ERIC
67 Convertible, 350CID, TKO600RR, 3.73 Eaton Posi
Old Jan 1st, 07, 10:37 AM
Question Re: What Rear End Fluid with Eaton Posi?
If it chattered you probably did not use an oil with limited slip additive?
  #11
Old Jan 1st, 07, 10:43 AM
Freddie
I have always used Amsoil from the beginning with no problems. Only the Severe Gear oil has the additive. This replaced the old Series 2000, which also had the additive.
  #12
Old Jan 1st, 07, 10:55 AM
I am thinking of trying the Redline Synthetic 75-90W GL-5 with friction modifier? Would that be a good choice?
  #13
Old Jan 1st, 07, 12:21 PM
Hogdaddy Hogdaddy is offline
mike
I just put a new 8.5 Eaton posi in and the instructions said mineral lube only and no where did it say its ok uses synthetic so have they not upgraded the instructions included with these posi's?
1967 convertible T-1
  #14
Old Jan 1st, 07, 01:11 PM
Eric
No, the bottle said "for limited slip differentials" right on it. The chattering stopped the day I switched to Valvoline. Redline probably makes great products, but the Eaton posi defintely does not like it. I called Eaton a while back and asked why they don't recomend the synthetic oil and they said it was "too slippery" and it caused thier unit to chatter. I know lots of you guys and gals are using Amsoil, and like it. I will stick with Valvoline because it works, and it's not worth my time to "try" something else.
ERIC
  #15
Old Jan 1st, 07, 01:25 PM
olympic69 olympic69 is offline
Thats kinda bizzare- I thought the chatter was the result of _innadequate_ lubricity/ film strength, and the clutch packs grabbing instead of slipping as they should, albeit under the high pressure of the pre-load springs and side gear forcing under load. That is why it is critical that limited slips use an extreme pressure (EP) lube or additive, otherwise the clutches will be damaged.
I think I would go with the consensus product(s) listed earlier in this thread- that being the Amsoil severe gear product which others have used with good result- in other words, you dont need to experiment!
Rob
Robert
'69 X-33 since 1984
"Its all crazy..."
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: What Rear End Fluid with Eaton Posi?
Location
Location
First Name
Human Verification
Similar Threads
'67 rear end swap - posi + discs Strick Brakes, Suspension & Steering 0 Oct 31st, 06 04:02 PM
Ford 9" Rear? BERRY251 Transmission & Driveline 15 Oct 11th, 06 05:28 PM
Question on install of leafs and rear end ray moore Brakes, Suspension & Steering 11 Apr 12th, 06 07:08 PM
Rear end work Ted DeWys Transmission & Driveline 7 Apr 11th, 06 03:20 PM
Eaton Posi Package on ebay Farm Boy Transmission & Driveline 5 Jun 17th, 05 06:53 PM
