Pro Touring Todays performance with classic style
Old Jan 3rd, 07, 06:52 PM
sv sv is offline
Default 2002 LS1 - what to check/replace
Hi guys - I'm starting a LS1/6 speed into a 69 camaro project.
Before the engine/transmission goes into the car is there anyting I should change/check while its out. It's a 2002 Firebird LS1 with 70K on it.
thanks
Old Jan 8th, 07, 02:10 PM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
Team Member
Jan
Default Re: 2002 LS1 - what to check/replace
You need to cut the oilpan for clearance around the steering linkage.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z-28, Cortez Silver, LS1 / T56
protouring.se
Old Jan 8th, 07, 09:02 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Team Member
Scott
www.ls1tech.com
Old Jan 9th, 07, 12:18 PM
Silver69Camaro Silver69Camaro is offline
Matt Jones
Jan
Assuming he's using a stock subframe. If that is the case, and it's a F-Body LS motor, you'll need new accessory brackets. But again, that wont be a problem if you're running an aftermarket subframe.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Similar Threads
Starting my LS1 converted 67 dheck Pro Touring 5 Nov 1st, 06 05:38 AM
LS1 Brake Swap Pics noels69 Brakes, Suspension & Steering 3 Jun 6th, 06 11:35 PM
Ls1 booster and master cylinder Midnight68 Brakes, Suspension & Steering 12 Apr 17th, 06 08:20 PM
Aren't all 2002 Camaro 35th Anniversary? 1969 Camaro Dude Bench Racing 5 Nov 26th, 05 08:23 PM
Supercharged 2002 LS1 Camaro Fuzzmaker Camaro Tech 4 Apr 11th, 05 11:46 AM
