Third Generation 1982-1992
Old Jan 6th, 07, 08:14 PM
drcolmen drcolmen is offline
Daniel
Default Engine (dieseling) Stay On After Turned Off Help!!!
I Have A 84 Camaro Z28 Ho That Stays On A Couple Of Seconds After The Ignition Switch Is Turned Off. (kicks And Sputters)
I Have Already Adjusted The Timimg And Still Does The Same. Does Anybody Have Any Suggestions??? Any Feedback Will Be Appreciated..
Old Jan 6th, 07, 09:30 PM
aaronjohn20 aaronjohn20 is offline
Tech Team
Aaron
Default Re: Engine (dieseling) Stay On After Turned Off Help!!!
does your car have the electronic timing or the vacuum. If it's got the electronic, there is a wire you gotta disconect.
Old Jan 6th, 07, 10:06 PM
JimM JimM is offline
Jim
84 would be an electronic q-jet and conventional hei...and lotsa vacaum hoses and valves and things.
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI
04 Silverado SS The Black Beast
93 Polo Green Corvette
http://www.Jimragtop.com
Jim's NEW Blog!
Jim Cam
Old Jan 6th, 07, 10:33 PM
wiskeesour's Avatar
wiskeesour wiskeesour is offline
Team Member
Harley
sounds like the vaccum advance isnt working properly? is it moving freely? dieseling is usually just the timing a hair off, right?
AE2(AW) Harley Moody, USNavy
"Master-at-Arms" for the CDWJB!!
November 26th, 2008 was my last day to serve my country as a member of the World's Greatest Navy.
Thanks Chief.
Old Jan 7th, 07, 12:27 AM
Camaro Dave Camaro Dave is offline
What are you idling at? It is possible your RPM's are too high as well as the timing is off. Double check your timing first, with the vacuum advance disconnected.
67 RS Camaro 327/ 350 Holley 650cfm > Edelbrock Performer Intake > Pertronix Ignition > Accel Super Stock Coil and Wires > Hedman Hedders > Hotchkis Performance Springs > 15" Rallys all around
Camaro buds until the end!!!
Similar Threads
Learning from revamping blower engine Tokyo Torquer Performance 11 Jan 24th, 07 01:44 PM
Wiring Issue After Engine Swap Help Please!!!! tourville87 Engine 0 Nov 11th, 06 02:59 PM
WHY KEEP ENGINE RPMS under 7000rpm grumpyvette Performance 50 Oct 4th, 05 10:39 AM
Engine dieseling problems. ck 2 Performance 16 Apr 14th, 05 06:53 PM
What engine is this inside of my 67 Camaro?? camaro_town Tag Team 3 Apr 23rd, 04 06:14 PM
