| Team Camaro Tech Current Topic: You guys with huge tubs ... | ||
| Pro Touring Todays performance with classic style |
A question for you pro street guys with narrowed rears and huge tires.
Are they very street-able ? do they hop when turning a tight corner ? Do they tear up diffs ? |
your not going to take a turn doing 50mph but you dont need to go 5mph it really depend on the rear weather it it a spool , locking rear or limited slip I run one for the street 4:11 and on the track i run a spool with 4:56----------9 inch
70 RS Pro-Street 69 RS/SS wifes car ![]() 07 Tahoe LTZ 02 2500 crew LT Duramax 04 Fatboy www.racealley.com |
I have a Ford 9" factory posi 4:11 gears, narrowed 23 inches. Rear 15x15 wheels w/Mickey Thompson Sportsmans (31x18.5x15). I have no "hop" issues at all driving on the street. With the exception of some poorly maintained roads in town, I'd say it rides fairly smooth. I wouldn't think you'd have any hop/drag type of problem unless you're running a spool.
Blown 69 RS Camaro {Work in process - Current Photos} 383 Small Block Dyno: 578 Horse - 595 LB/Torque |
I had the Hoosier Pro Street Radials (31 x 18.5 x 15) on the back of my Nova. Like softail02 said, you're not going to take a turn at high speed, but you don't need to creep around the corner either. It also depends on your rear suspension. I had to have mine stiffened up to control the body roll during turns. It wasn't great over the bumps, but it was streetable.
==Doug Former 69 Camaro owner,70 Pro Street Nova owner Current 69 Camaro owner (pics of resto project), SIM member |
Have a spool w a 9 and 31x16.5x15. I dont have any prob if I run higher air pressure for cruising around, but w man steering and a spool it gives your forarms a workout. I thing the tires being so big absorb the wheel binding issuse you might have with a spool and smaller tires.
So they're not as bad as I thought
are there any areas where they wear out drive train parts faster than normal ?
Similar Threads
| Collision shop guys, what is your filler/primer procedure? | MARTINSR | Body Shop | 10 | Sep 26th, 06 09:31 PM |
| what do you guys think of these BBC heads? | meanZ | Performance | 15 | Aug 10th, 06 08:12 PM |
| Pleasanton Good Guys Show 6/3 to 6/4 | Gregs68U-U | Team Camaro Cruiz-Ins | 6 | Jun 6th, 06 09:16 AM |
| I'm beggin' you guys... | Thatoneguy | Body Shop | 5 | May 21st, 06 09:46 AM |
| big block NOS guys help please | victtor | Performance | 4 | Jan 2nd, 06 12:47 AM |
