| Team Camaro Tech Current Topic: A Arm dust shields | ||
| Body Shop Paint & Body Forum |
Just opened my box from Re Pops for replacement dust shields for upper A arms. However there are no instructions and my car didnt have any. I can figure out the 2 pieces that look like they go on tne inner wheelwells however there are 3 other pieces in the box that I have no clue. Any tips?
| Sponsored Links | ||
Advertisement | ||
If you will check the assembly manual, it shows the location of all the sheilds.
TZ
Mike Daytona Yellow 69 Z/28 69 coupe, 454 and 400 turbo 67 convertible project (the money pit has been opened) |
Two of the pieces staple to the bottom of the inner fender, and seal off the area between the inner fender and the subframe. The other is for a bracket on the driver side that shields the Zbar and extends horizontally toward the outside.
Trenton is right, If you don't have the assembly manual, you should get one. You will thank yourself at least a hundred times during your restoration. Best $20 you will spend on your project. |
Jeesh, Im such a dope. I have the manual and never even thought of it as I was in a panic to get the car to the painter. Thanks, I will look.
Does the hole in the rubber shield under the master cylinder attach to the lower bolt of the bracket? Where does the slot in the rubber shield attach? Mine had the piece attached to the braket, but the horizontal piece was torn off.
"Government is not reason; it is not eloquent; it is force. Like fire, it is a dangerous servant and a fearful master." ..... George Washington Gary,TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original. |
The hole in the horizontal piece is for the e-brake cable. There's a clip that goes on the outside of the shield that clips to something---I think the edge of the inner fender, but I can't remember, for sure.
How about the slit and the notch cut in the shield?
| Sponsored Links | |
Advertisement | |
