BBC how to tell steel from cast crank?? - Team Camaro Tech
Thread Tools Display Modes
Old Jan 9th, 07, 03:44 PM
dubs68camaro dubs68camaro is offline
Default BBC how to tell steel from cast crank??
I was just told by a machine shop that I have a steel crank but I thought it was a cast. How do you tell the difference????? The only numbers I could find were GM1 13.
Old Jan 9th, 07, 03:52 PM
pdq67 pdq67 is offline
Banned
Default Re: BBC how to tell steel from cast crank??
A forged crank will have a wide parting line that's like 3/8's to a 1/2" wide due to when the excess metal was cut off it from the forging operation.
A cast crank will have a real narrow parting line like less than an 1/8th inch wide.
And you can tap a counterweight on a forged crank with a small ball-pein Ford tool and it will ring like a bell whereas a cast crank kinda just goes thud!!
pdq67
Old Jan 9th, 07, 05:37 PM
Nice!!!! That baby has a 1/2 mark all the way down the crank!!! Can you say "bonus"?? Thanks guys!
Old Jan 9th, 07, 06:07 PM
Larger Dave Larger Dave is offline
Dave
Cool Re: BBC how to tell steel from cast crank??
They say a picture is worth a thousand words, so here are a few hundred because the images aren't that great.
Note the parting line on this Scat Chevy Cast 383 crank on the counter weight by the 5-6 throw and again on the flywheel flange. It appears as a straight narrow line.
SCAT Cast Crank
This is the standard stock cast iron crankshaft I pulled out of my old SBC 400 before I replaced everything but the '509 block. It can be enlarged enough to see the parting line if you down load it and blow it up as it is a fairly large image (unless photobucket shrank it as I'm a little fuzzy on image size upload down load thing).
Stock Cast SBC 400 crank
This is an Eagle Non-Twist forged crank. Note that the parting line, even though it has been ground down, lies in a straight line from one end of the crank to the other going through the counter weights and crank throws.
Non Twist Forged Crank
Compare that to an old magazine photo (sorry about the dithering) which shows a stock 5140 forged steel crank that was twisted to bend the crank throws 90 out going down the line. You can see the heavy parting line clearly going right through the main journal crossing it at a 45 angle. This is a good example of a forged parting line and why a non-twist crank is preferable.
427 Factory Forged Crank twisted
Larger Dave
Old Jan 9th, 07, 08:25 PM
davidpozzi davidpozzi is offline
David Pozzi
Have some fun!
Stand the crank on a rag, then strike one of the counterweights with a hammer. Don't worry, you aren't going to hurt it with a hammer tap.
It should ring like a bell!
David
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
Old Jan 9th, 07, 09:04 PM
jr68's Avatar
jr68 jr68 is offline
Team Member
Jerry R.
Originally Posted by Larger Dave View Post
Larger Dave
That would make a great end table and look great next to any recliner !
my Magnaflow X-pipe system sound clip, click the link
http://s258.photobucket.com/albums/h...naflowclip.mp4
Old Jan 9th, 07, 10:16 PM
CDJr CDJr is offline
CDJr
Or a redneck lawn ornament
Old Jan 9th, 07, 10:36 PM
Fred Ficarra Fred Ficarra is offline
Fred
The old tapping hammer is the only tool you need.
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's tru-tack posi, ducted hood, Endura, spoilers.
TH400 (CX) with Coan 8" converter, GV-OD, 8 track still on console and best et 10.495, 128.79mph 1.428 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers & 3" full exhaust with X pipe.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
http://ss427.net/
Old Jan 10th, 07, 10:28 AM
Banned
Ding, Ding, Ding!!
Morris, it's din, din time!!
He, He!!
pdq67
PS., anybody remember the old "Morris the Cat" commercials?
Old Jan 10th, 07, 11:00 AM
jr68's Avatar
Team Member
Jerry R.
So many baby boomers on this site Im sure most of us do
  #11
Old Jan 10th, 07, 01:57 PM
67 Plum's Avatar
67 Plum 67 Plum is offline
Chad
I do.
  #12
Old Jan 10th, 07, 03:50 PM
Busted Knuckles Busted Knuckles is offline
I've had a few cast cranks that rang like a bell, too. Parting line is your best bet for telling what you have. I've gotten to the point where I can look at the back flange on one and tell without having to pull the pan. This doesn't work on the late model 1-piece rear main stuff, though.
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
  #13
Old Jan 10th, 07, 08:33 PM
Banned
Right you are Gary, the dam things are round with no "fans" on them anymore..
pdq67
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: BBC how to tell steel from cast crank??
Location
Location
First Name
Human Verification
Similar Threads
Eagle 383 cast crank ? bdcole_51 Engine 9 Sep 7th, 06 10:13 AM
Bearings for a steel crank supercharged sbc Engine 4 Apr 1st, 06 09:56 AM
bbc crank pulley mydogfrank Engine 1 Sep 25th, 05 09:53 PM
3-way crank gear any ideas hideaway Engine 7 May 9th, 05 06:42 PM
350 cast steel crank Burney Tech 2000 6 Mar 26th, 01 06:12 AM
