replace 67 camaro heater core - Team Camaro Tech
Camaro Tech General Tech Area
Thread Tools Display Modes
Old Jan 9th, 07, 10:32 PM
judobum judobum is offline
Don
Default replace 67 camaro heater core
I am replacing the heater core in my 67 SB Camaro.
I was told I could turn the box box upside down and
use a 68 box and that would move the copper tubes
where thay were more accessable. What do you think?
Will I have to take off the front fender to do it?
Old Jan 10th, 07, 10:30 AM
TJS69 TJS69 is offline
Tom
Default Re: replace 67 camaro heater core
I'm not sure what is meant by turnining it upside down. The heater core is inside the passenger compartment - under the dash. You will have to remove some bolts on the engine side, but the fender can stay on.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Jan 10th, 07, 11:22 AM
rafbody's Avatar
rafbody rafbody is offline
Russ
The heater box is the same for a small block in 1967 and 1968, I suspect they are confused with the big block heater box. The big block heater box has the copper tubes coming out in the middle of the heater box.
Russ
'67 4 speed coupe
'67 rs coupe
'94 6 speed z-28
Old Jan 10th, 07, 12:36 PM
thorpe67RS thorpe67RS is offline
Craig
You dont have to remove your fender to change the heater core. You will have to pull the nuts of the studs on the firewall where the heater box goes thru. Remove your glove compartment box and you can pull the heater box back to expose the heater core. ie..all done inside the car under the dash. Its actually pretty easy..took me less than hour when i did mine.
Old Jan 10th, 07, 12:49 PM
36j1967 36j1967 is offline
Pat
Where are you guys that are changing the heater core from the inside getting your cores? I've changed a couple lately and the bend on the tubes attached to the core prevent it from threading through the firewall holes. The only way I could get it done was loosening the fender and removing the core cover from the engine compartment side PITA!
1967 IPC 0-1 L35/M40
1968 RS/SS L78/M22
1969 Z11 L34/M20
Old Jan 10th, 07, 01:04 PM
Craig
Not sure what to tell you. Theres not a lot of wiggle room for sure but mine went thru with no real problems. Did it on both the Camaro and Firebird and it worked for both. Wish i could be more help. Oh..forgot to answer your question...I got both cores from Advance Auto. Which i believe were made in Mexico...not sure how thats gonna work out in the long run.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Camaro Tech      Current Topic: replace 67 camaro heater core
Location
Location
First Name
Human Verification
Similar Threads
Heater core seal necessary? italiano362 Heating & Cooling 1 Jan 5th, 07 05:17 AM
Hearer Core, Replace or Not, Your opinions Buildinga55 Heating & Cooling 4 Jan 9th, 06 08:32 AM
HEATER CORE QUESTION neverswt Tech 2000 1 May 22nd, 01 11:21 AM
79 Camaro & heater core replacement... again Patrick#44 Tech 2000 1 Feb 6th, 01 10:00 AM
