| Team Camaro Tech Current Topic: Loud bang when I punch it =( | ||
| Fourth Generation 1993-2002 |
I just bought a 94 camaro last night...Everything seemed okay when I test drove it, but last night I was driving and I punched it...and it made a loud bang from underneath the car...It sounded like a bowling ball shot up from the ground and hit the bottom of it! It does that everytime I punch it...Does anyone know what that could be?
Congrats on the Camaro purchase. Tell us more about your car, auto or stick, v-8 or v-6, etc. Where is the noise when you punch it, does it sound like the engine compartment or does it sound like it is coming from under the passenger compartment or does it sound like it is coming from the back of the car. First guess - trans mount or motor mounts. Post some more info and youll prob. get more responses. - Rob
We do not possess imagination enough to sense what we are missing.
Its a 350 v-8 automatic. The noise sounds like it is coming from the very middle...Maybe a little more towards the front.
Red 94 I am not familiar with those computer controlled car's it could be just about any thing with them from the opti spark ,plugs ,clogged cat does any codes come up ,I had a 97 z-28 and really I think you may have better luck at z-28.net…here is the link …good luck and Happy Motoring
68 Coupe, LeMans Blue , AFR-ZZ-4 ,TKO600 , 12 Bolt 3:73 , Hotchkis T V S . http://i217.photobucket.com/albums/c...chool038-2.jpg http://i217.photobucket.com/albums/c...9-27-08006.jpg http://i217.photobucket.com/albums/c...-7-08011-1.jpg http://i217.photobucket.com/albums/c...10-7-08010.jpg |
Check the transmission mount.If it is broken the torque arm pushes the trans. up into the floor of the car.
67 Plum Mist Met. 408 TH350 3.08 posi http://www.youtube.com/watch?v=FtZfepG5-m8 http://s703.photobucket.com/albums/w...t=MVI_0678.flv |
Either that, or you need a tune-up.
*-------------* ...'69 Camaro *-------------* http://streetmachinesofrochester.com/main.htm |
http://web.camaross.com/forums/
I would check the transmission mount first, good luck.
#11
Check The Read Mite Need New Suspension Bushings
Got to give the PEOPLE what they want! Look....if you wanna be the best then you gotta take out the best! 1967 Prostreet Camaro BB 431 650hp 400 Turbo Trans Ford 9" 4:56 gears http://www.cs3automotive.com/index.php |
#12
My third generation firebird had a "torque arm" running from the rear end to the side of the transmission...
I used to break the mounts at the trans... when I would hit the gas, the torque arm would hit the bottom of the car....
Allengator TC #3240 ACES #07491 Po' Boys Classic Car Club Ft Worth, TX 1966 Chevelle Malibu Ragtop 1951 Chevy Sedan Delivery |
#13
Yeah, I concur on it probably being a bad mount. Put it up on lift, then put in gear, with foot on brake, and rev engine up. You will probably see something move that's not supposed to.
I would also look at all other chassis components while under there. Could be something weird, like broken spring, bad shock, u-joint ready to fall apart, etc, etc...... Nice thing is: it should be easy to spot the problem! -
Dave F. in Rhode Island '68 Camaro SS Accel DFI 454 Bought my first big-block Chevy in 1970 |
#14
I had a '71 vette with almost the same problem. Because vette's hood open the other way, I was able to see the problem easily. Let me tell you....when your are not expecting that, it can be quite a site to see your motor almost come out of the car!!
The only problem is that depending on hood clearance, I think you would probably hear that problem more when you let off the gas and it slams back onto the pad rather than it hitting the hood. East fix though.....just get a friend to stand in front of the car with the hood open and do the old "gas and brake" at the same time. That will tell for sure if it's a broken motor mount. |
#15
Friends 97 Camaro did it too. Transmission mount. Sounded likke it was coming thru the floor.
Dennis 69 Z/28. 302DZ, Autogear M22, Red w/black stripes. 69 Camaro, ZZ4, TH350. 8.5 3:42 posi, X11 (in progress) 87 IROC (in progress) 86 Z28 (Not sure what state that's in) |
Similar Threads
| Greenlee punch question | smith69z | Restoration Corner | 15 | Apr 25th, 07 09:26 PM |
| loud bang coming from underneath | jr68 | Brakes, Suspension & Steering | 7 | Oct 9th, 06 08:24 AM |
| Loud pipes, legal for Harleys, not cars. Why? | b-boy | Bench Racing | 14 | Nov 21st, 05 06:55 PM |
| Why are my hooker muffler not loud? | Tom Ziokowski | Performance | 5 | May 24th, 05 10:14 AM |
| 1 chamber Delta Force Flowmasters? Too loud? | Chris88Z | Performance | 12 | Jan 9th, 03 12:17 PM |
