Fourth Generation 1993-2002
Old Jan 18th, 07, 06:12 AM
dwnrvr19 dwnrvr19 is offline
George
Default Water pump on a 97 3.8
My water pump is starting to go. It looks like I will have plenty of space to R&R the water pump without taking the radiator out. Am I too optimistic, or should I plan to take the radiator out? Does anyone have some advise on how much of a hastle this will be, or how long it should take?
It is a 97 5 speed with a 3.8. Thanks
Old Jan 18th, 07, 12:30 PM
Bowtie68 Bowtie68 is offline
Lee
Default Re: Water pump on a 97 3.8
I had the 5.7L engine so my setup was a little differnt then yours but I didnt remove the radiator when I swapped my WP out. Yes take off all the electric fans and everything else in your way to the pump and that should give you enough room to take the pump out. I did all my work from underneath the car as well.
1968 Camaro with a 383 finally done and on the road!
Old Jan 18th, 07, 07:03 PM
George
Thanks I think I will start out that way, and if I need to then I will remove the radiator
Similar Threads
327 with short water pump and running the fuel line woes 30lbtest Engine 12 May 3rd, 07 03:05 PM
short water pump or long water pump??.... PLT-1 Engine 5 Jan 28th, 06 09:47 AM
Water Pump 62bakes Engine 5 Nov 5th, 03 06:55 PM
Water Pump Woes… Z28 Mark @home Performance 7 Nov 5th, 02 04:38 PM
short water pump vs long water pump mark67ss Tech 2001 13 Oct 18th, 01 06:45 AM
