327 cam selection - Team Camaro Tech
Old Jan 18th, 07, 04:47 PM
84camaroinprogress 84camaroinprogress is offline
joe
Default 327 cam selection
got a stock bottom 67 327 with 601 305 heads, performer rpm, 650 vacuum sec, 1.5 rockers, current cam is a speed pro .468 .480 hyd 220/231 dur, lsa 110 rpm 2200 to 5700rpm 304/287 avg dur. the cam was originally bought for a 305 i use to run and it ran real good surprisingly till i spun a bearing and i had the 327 short block sittin there so i slapped the heads on and used the same cam. im now lookin for a solid lift cam to go with the rpm range and compression of this motor
Old Jan 18th, 07, 05:11 PM
pdq67 pdq67 is offline
Banned
Default Re: 327 cam selection
See my other post..
And fwiw, a hy-cammed about 9.75 to 10 to 1 CR. 327 engine will run like a "scalded-dog" with no more than a........
CC 268HE and 270 Magnum;
Crane/Cam Dynamics 272/272 Energizer and 274H-06; and an
Isky 270 Mega....
Notice NOTHING fancy here at all...
I personally like the smaller solid cam's b/c the little motor likes to rpm!! At least up to 7,000 rpm with good springs like no more than a cheap set of Z-28, (i.e., -142), springs...
pdq67
Old Jan 18th, 07, 06:39 PM
joe
where do i get the z28 springs right now my springs are only good for .490 lift
Old Jan 19th, 07, 06:07 AM
Banned
Smile Re: 327 cam selection
That should be them! Some places list .490" and others, .510"..
Or try Competition Products and Midwest Motorsports. MWM's stock dia. shorter Elgin springs are them..
Summit too I figure. They run like $25/set!! Excellent value to me....
The 1970 and later, LT-1 springs that went with the old -178 solid cam are in here too but usually they are about $10 higher per set... Go figure???? Still good value to me tho!!
pdq67
Similar Threads
406 sb cam selection & power estimates SooperDave Performance 44 May 16th, 07 06:14 AM
CAM selection Raysdz Engine 7 Aug 18th, 06 07:50 AM
327 cam help gobtool Engine 9 Jan 19th, 06 10:48 PM
Lobe Separation Angle questions 69ProTouring Performance 19 Oct 10th, 05 05:41 PM
383 cam selection? cakneller Engine 8 Apr 22nd, 05 09:49 PM
