Fourth Generation 1993-2002
Old Jan 23rd, 07, 01:17 PM
AirMarcus AirMarcus is offline
Default Mcleod master cylinder
Finished the drill mod and am assembling the system again. Would anyone think it is a mistake to use a stainless 1/8" cotter pin instead of the roll pin used to secure the line to the master cylinder. It should be close to the same diameter. It would be nice to reach down there and snatch out the cotter to remove the line instead of removing the heatshield that is behind my headers to remove the whole unit. Of course, if it leaks, I'll have to remove everything to fix it.
Similar Threads
Mcleod Master cylinder AirMarcus Transmission & Driveline 0 Jan 23rd, 07 09:32 AM
69 Manual Front Disc Brake Master Cylinder jeff5295 Brakes, Suspension & Steering 26 Nov 2nd, 06 11:33 PM
1967 Disk Brake Master Cylinder size/part#? 69RS/SS396ragtop Restoration Corner 0 Oct 22nd, 05 10:15 PM
Master Cylinder for Disc Brakes? ItDoRun Brakes, Suspension & Steering 3 Aug 22nd, 05 10:35 PM
What have I got - Master Cylinder dnult Brakes, Suspension & Steering 8 Jun 16th, 03 07:14 PM
