| Team Camaro Tech Current Topic: Oil Pressure question | ||
| Fourth Generation 1993-2002 |
I am looking at a 1995 Camaro with the 3.4L V6 for a daily driver. Drove it today and noticed the low oil light was on at start up. Turned it off and checked the oil level- plenty of oil. Started it up again, low oil light on for a minute, then goes off. Faulty oil pressure sensor? The oil pressure guage also seemed to read low at idle after the car was warm. What is the typical oil pressure for a warm 3.4 V6? This car has 123000 miles. Any help would be appreciated.
I would probably say pressure sensor needing replacement first.
Normnal oil pressure is the same as a SBC, 40-50 hot @ 2000-2500 rpm, 15-25 @ hot idle. However, oil filter points down or sideways, oil drains out over night, start-up cold or after sitting for a long time, pump has to fill up the filter first.
Give a man a rescue dog for the health of his soul. My 68 Camaro http://www.flickr.com/photos/everettwn68 |
Oil pressure sending unit possible.
I've got a '94 3.4L and I've had to change the oil pressure sending unit at least 5 times (maybe 8, can't remember) since 1994. This also happened on an '84 Firebird many years ago. In all cases the gauge started jumping all over the place (from 0 to 80 psi, and any place in between, for no apparent reason). It's fairly easy to change when replacing the filter.
hope this helps Brad |
Thanks for the input guys. I ended up buying another Camaro instead of this one. See my latest post for this cars woes...
Similar Threads
| Oil pressure issue | DirtyScotty | Engine | 14 | Aug 21st, 06 07:43 PM |
| leaking oil...is my pressure to high? | Eighttrakz | Engine | 14 | May 11th, 06 11:39 AM |
| oil pressure question/problem. | iroc5570 | Engine | 6 | Aug 27th, 05 12:08 PM |
| Oil Pressure Drop BBC | 68camtruck | Engine | 3 | May 5th, 05 05:16 AM |
