| Team Camaro Tech Current Topic: Check engine light after engine hesitates? | ||
| Fourth Generation 1993-2002 |
The vehicle is a 95 z28 with 111,000 miles with no record of spark plug change. The situation is worsening. It will stumble one time per check engine light. It will happen under hard acceleraton and cruising with little throttle.
mine did that, then gave me a random misfire code it was bad plugs let it go it got worse, changed plugs it all went away, if that helps
96z28,cold air kit and headers and borla cat system, to get me started in the darkness i will find you
that is what I think is going on. I am gonna have the computer checked at advanced for the light keep coming on. May be condensation in the tank with a blocked fuel filter. Thank you for your response.
Found problem. Dirty mass air flow sensor.
Similar Threads
| Check Engine Light Issue! | snowman_az | Electrical & Wiring | 0 | Mar 20th, 06 04:31 PM |
| 83 berlinetta egr Qjet check engine light??? | scooterick | Camaro Tech | 0 | Feb 23rd, 06 04:07 PM |
| Service Engine Light | aaronjohn20 | Troubleshooting | 8 | Jul 13th, 05 07:19 AM |
| check engine light | lest13 | Tech 2000 | 1 | Jun 22nd, 01 03:03 AM |
