Brake and bore size question ? - Team Camaro Tech
Old Jan 31st, 07, 09:38 AM
mnm99's Avatar
mnm99 mnm99 is offline
Marc
Default Brake and bore size question ?
Long story short I am trying to get my brakes to work again. Old setup was a 11" booster with 1 1/8 master and large piston calipers. That setup worked ok,but I need a smaller booster (bigger engine) and want to get this to work. After installing the 8" duel Dia booster the brakes got very hard and could not stop. Here's my question. I have 12" of vac at idle. I bought a canister but didn't hook it up yet.
If I went with a 1" bore master and relocated the brake pushrod like a manual brake setup ( top hole ) by getting a different bracket to to mount the booster and added the canister do you think that would do it? Could I go to a 15/16th bore and still have pedal left?
I know about vac pumps and hydroboost. I wanted to see if I can get this to work first.
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B]
Old Jan 31st, 07, 07:54 PM
davidpozzi davidpozzi is offline
David Pozzi
Default Re: Brake and bore size question ?
If you used the top hole and a 15/16" bore master cyl with pushrod in the upper hole, you wouldn't need a booster at all. That might be a good option.
Just by switching pedal holes, you are doubling the pedal ratio.
Power is 3.8 to 1, Manual is 6.25 to 1.
A drop from a 1 1/8" bore to 1" bore would give you aprox 1/3rd more power alone.
Code:
On the bore size:
Bore ......Area sq in
1 1/8"   .994
1"         .785"
15/16"   .693"
7/8"      ..601"
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
Old Feb 1st, 07, 03:35 AM
mnm99's Avatar
Marc
I ended up just shimming the booster for now so it lined up with the top hole. What a difference! I do have alot of travel now though. How high should the pedal be off the floor for manual brakes? I had to remove the brake switch stopper for the rod. I ended up adjusting the brake switch back down 3/4.
Similar Threads
master cylinder bore pappy's69 Brakes, Suspension & Steering 2 Dec 30th, 06 09:45 PM
A few questions about a drum to disc front brake conversion... Cougar207 Brakes, Suspension & Steering 2 Sep 10th, 06 10:26 PM
How do I remove this brake rotor? Gehrkmania Brakes, Suspension & Steering 18 Mar 20th, 06 08:49 PM
Another brake question kelemor Brakes, Suspension & Steering 2 Jun 1st, 05 08:24 AM
Brake Hose Banjo Bolt For PBR Calipers-Where To Get Them? Go69 Brakes, Suspension & Steering 5 Oct 12th, 04 06:31 PM
