What is this intake from...any idea? - Team Camaro Tech
Old Feb 1st, 07, 01:10 PM
Tom Ashmead Tom Ashmead is offline
Default What is this intake from...any idea?
I just picked up a GM aluminum intake for a small block & was wondering if anyone knew what it might be off of.
The casting # is:
14007378
Thankyou for your time...Tom
Old Feb 1st, 07, 01:15 PM
SixtyAte's Avatar
SixtyAte SixtyAte is offline
Kevin
Default Re: What is this intake from...any idea?
Tom...
I believe that intake manifold 14007378 is for a '79 L-82 corvette
Kev
Old Feb 1st, 07, 03:10 PM
Thanks,Keven.
Any idea if it's worth anything?
I might use it on a later project,but for now it's just in the way.
Old Feb 1st, 07, 03:27 PM
dubs68camaro dubs68camaro is offline
I think that's just a standard intake.....is it a spread bore? As we know, there wasn't much horsepower being produced from the factory in '79. I think most of the components back then were more about gas mileage and emissions than anything else. Probably would look good on the garage wall and that's about it.
Old Feb 1st, 07, 03:52 PM
67 Plum's Avatar
67 Plum 67 Plum is offline
Chad
Actauly the late 70s early 80s factory aluminum intakes flow better than the late 60s early 70s stuff.
Old Feb 1st, 07, 03:58 PM
oger oger is offline
The alum ones with EGR tend to warp the mating surface on the EGR side. Before you try to use it lay a straight edge along the mounting surface to the head to see if it's straight.
Old Feb 1st, 07, 05:27 PM
I am not sure if it's a spread bore or not...I'll havt to look at it tonight when I get home.I'll check for flatness too.
Thanks again...Tom
Similar Threads
solid lifter adjustment jks67SS396 Engine 11 Jul 11th, 05 07:40 PM
Vortec intake leak AGAIN nitrous383 Engine 8 May 4th, 05 09:05 AM
Intake manifold corrosion travis Engine 9 Mar 18th, 05 06:58 PM
Edelbrock finally finished the carbed LS1 intake! MY FIRST 69 Performance 17 Oct 19th, 04 08:32 AM
Pro-topline heads...other intake and gasket options travis Performance 5 Aug 26th, 03 10:13 PM
