Camaro Weight - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 28th, 00, 11:34 AM Thread Starter
Does anyone know where you can find approximate weights of camaros? If not about how much 85 camaro sc weight?
stalemate is offline
post #2 of 7 (permalink) Old Jan 28th, 00, 12:33 PM
i think the curb weight is about 3100-3200lbs. depending om the options you have. i am not totally positive on this but pretty sure. if you want to know the true weight of the car find a local junyard or somewhere that has a drive on scale and see if they will weigh it for you. my friend did this
Tom Ziokowski is offline
post #3 of 7 (permalink) Old Feb 2nd, 00, 07:57 PM
I had an 85' z-28 with t-tops & power windows
air conditioning, and it only weighed
3120 lbs.
68'camaroguy is offline
post #4 of 7 (permalink) Old Feb 3rd, 00, 05:44 AM
I agree with the scale method. If you are using the weight for calculations you may want to weigh the car while you are in it to get more accurate calculations.
Kent
67 SS 427
kwissman is offline
post #5 of 7 (permalink) Old Feb 10th, 00, 09:30 PM
go to a truck weigh station to find out the approximate weight of car. first ask before you just show up though
Athorn4941 is offline
post #6 of 7 (permalink) Old Feb 11th, 00, 04:21 AM
Some of your larger moving companies will have scales that, for a fee, you can use. I have a company here in Houston called Graebel Movers that do it for $6 a pop. They have to weigh the trucks when loaded to be sure they are not over weight. I would think that other moving companies do the same thing. Good luck
Go69 is offline
post #7 of 7 (permalink) Old Feb 11th, 00, 01:56 PM
Wink
I have an 89 that comes in 3350lbs
Pro Tour RS is offline
