vacuum advance - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 3rd, 00, 02:10 PM Thread Starter
Does anybody run they're stock GM HEI without the advance hooked up? Can you just set your mechanical and leave it at that? Do you have to use the advance? Right now I'm running without it, and it doesn't seem any different
jokerdwarf is offline
post #2 of 5 (permalink) Old Feb 3rd, 00, 03:32 PM
Johnny
joker my vacun advance went out & my 327 was hard on gas & had stumble & no power.
johnny
johnnyr is offline
post #3 of 5 (permalink) Old Feb 4th, 00, 05:55 AM
Gene
Your distributor will need to be recurved if you don't use the vacuum advance. I think you want your mechanical advance to come in much faster when you don't have vacuum advance. You won't get the best performance by simply disconnecting the vacuum advance.
gheatly is offline
post #4 of 5 (permalink) Old Feb 4th, 00, 06:04 AM Thread Starter
Thanks guys....Ronnie
post #5 of 5 (permalink) Old Feb 6th, 00, 08:57 AM
David Pozzi
davidpozzi's Avatar
You need a vaccum advance for street use. For full throttle applications you don't need the vaccum advance. The vaccum advance operates under higher vaccum conditions like part throttle crusing conditions. Less during 3/4 throttle, and not at all under full throttle. If you disconnect the vaccum advance on a stock distributor, your engine will be running retarded during part throttle conditions. This will cause the plugs to run cooler which will cause buildup of carbon deposits. Also your mileage will suffer and the engine could load up so much on a long trip it could stall. I had this happen to me! Full throttle performance will not change except where the carboned up plugs will misfire if too dirty.
If you recurve the mechanical advance correctly, you may be able to get by without the vaccum advance and only loose a little mileage. The usual problem is when the mechanical advance is modified to get better full throttle performance, the stock vaccum advance has too much advance and at too low a vaccum. The vaccum can needs to be changed to one with less total advance, or limited with a stop, and have a stiffer spring inside to come on only at higher vaccum. The typical symptom of an over active stock vaccum advance is a brief ping when accelerating from a stop. The vaccum advance opens all the way when you first open the throtle, then takes a little time to close as you get into the throttle and the vaccum drops. While the vaccum advance is closing the mechanical advance is opening (on a recurved distributor) and you get too much advance briefly, causing a ping. Regards, David
davidpozzi is offline
