Rear Gear Ratio - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 4th, 00, 09:49 AM Thread Starter
Please someone tell me how to calculate my rear gear ratio without opening the diff??
It's even out of the car--67 camaro--327/ 3 speed.
BigBob is offline
post #2 of 6 (permalink) Old Feb 4th, 00, 09:53 AM
Wink
Have someone push the car and count how many times the drive shaft turns to one tire revolution.
Pro Tour RS is offline
post #3 of 6 (permalink) Old Feb 4th, 00, 09:55 AM
Mark yout drive shaft and tire, jack rear tires off ground(use proper jack stands) rotate tire one revolution. Number of times drive shaft turns is approxamate gear ratio. Refer to known ratio offerd in rear end it will be closest match.
snakedr is offline
post #4 of 6 (permalink) Old Feb 4th, 00, 09:57 AM Thread Starter
Talking
<BLOCKQUOTE>quote:</font><HR>Originally posted by Pro Tour RS:
Have someone push the car and count how many times the drive shaft turns to one tire revolution.<HR></BLOCKQUOTE>
The Driveshaft turns approximately 1.6 revolutions per hub rev. What would the make the gear and do you know the formula?
BigBob is offline
post #5 of 6 (permalink) Old Feb 4th, 00, 10:21 AM
For example, a 4:11 rear gear the drive shaft will turn 4.1 times to one tire revolution. Its impossible for your shaft to turn 1.6 times to one hub revolution.
Hope this helps
John 89 Pro Touring RS
post #6 of 6 (permalink) Old Feb 4th, 00, 11:02 AM
Bryan Shook
If you drive shaft only turned 1.6 times, you have an open diff and need turn the wheel two times. This will probably give you about 3.08 gears. The way pro tour and snake told you works only with Posi diffs.
Since its out of the car, you can look on the passenger side, forward facing axle tube and post those stamped numbers. They will tell you what gear ratio originally came in that rearend.
Bryan Shook
Favorite Quote - Some people have shrinks. Some people have their garage.
www.geocities.com/motorcity/speedway/6673
[This message has been edited by elcamino72 (edited 02-04-2000).]
elcamino72 is offline
