69 ID code - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 8th, 00, 09:32 AM Thread Starter
I have the folliwing ID an was wondering what the P201 means.
ST 69 12437 VN267124
TR 712 72 B
02C P201
VIN 124379L525124
yblab is offline
post #2 of 5 (permalink) Old Feb 8th, 00, 11:48 AM
Joe
the P201 is aparently a Los Angeles assembly plant work order code. there is no information available yet on what it means. check the following link for more info http://www.camaros.org/numbers.shtml
joe68rs is offline
post #3 of 5 (permalink) Old Feb 13th, 00, 02:53 PM Thread Starter
I have been to the web site before and was not able to get any where. Was hoping someone has seen the code and can tell me what it means. Thanks for your reply.
yblab is offline
post #4 of 5 (permalink) Old Feb 14th, 00, 10:43 AM
Jeff
The code is a production sequence code on the Van Nuys cars. Look for the chassis broadcast sheet on top of the gas tank. It gets glued there from the factory so be careful with it if it's there. If you find it, you may want to remove the gas tank so you don't damage it too much. This sheet will show codes for the engein, trans, rear, brakes, etc.
Jeff H is offline
post #5 of 5 (permalink) Old Feb 14th, 00, 07:19 PM Thread Starter
One of the first things I did was drop the gas tank looking for the build sheet, under the seats, carpet, dash board, I have looked in all the obvious places. I thought someone might have the same code so we could compare notes. I will be looking at every 69 camaro I see trying to find one unmolested car with the same code to see if it means something.
yblab is offline
