timing - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 11th, 00, 04:38 AM Thread Starter
I have a 305 that the timing chain jumped a tooth or so.I replaced the chain then the heads and intake do to bent valves.I have replaced every thing down to the cap and rotor and can't seem to get it timed right.can any body tell me what i am doing wrong?????????????????????
roadtoad is offline
post #2 of 5 (permalink) Old Jul 11th, 00, 05:40 AM
Thumbs up
Make sure you put the timing chain on at TDC on #1 cylinder with both valves closed and not 180 out. This used to get me a lot when I first started working on motors. The easiet thing I found is put your thumb over the #1 spark plug hole and turn over the moter until you feel pressure and you are on the compression stroke and where you want to be to put on the timing chain. You may already know this, if so disreguard.
68 RS, Ash Gold,pwr windows,Hounds tooth
CA420 is offline
post #3 of 5 (permalink) Old Jul 11th, 00, 06:32 AM Thread Starter
Thumbs down
the motor is at tdc but it still won't start when on number 1.it also sucks back through the exhaust <BLOCKQUOTE>quote:</font><HR>Originally posted by roadtoad:
I have a 305 that the timing chain jumped a tooth or so.I replaced the chain then the heads and intake do to bent valves.I have replaced every thing down to the cap and rotor and can't seem to get it timed right.can any body tell me what i am doing wrong?????????????????????<HR></BLOCKQUOTE>
roadtoad is offline
post #4 of 5 (permalink) Old Jul 11th, 00, 06:37 AM
Drake
Wink
Roadtoad,check your E-mail.
67 RS RAGTOP # matching
4X4 Chevy truck
4X4 Suburban
67drake is offline
post #5 of 5 (permalink) Old Jul 11th, 00, 04:50 PM Thread Starter
Wink
thanks for your help i got it going.
roadtoad is offline
