torque Specs - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 14th, 00, 12:19 AM Thread Starter
I need to change my intake manifold gasket on my Camaro. Can anyone help me out with it. I need to know what to torque the bolts to. Or can I just bolt them thing on. I have a 350 motor
CamArrow is offline
post #2 of 5 (permalink) Old Jul 14th, 00, 01:36 AM
ok install the bolts and working from the center outward tighten the bolts to 20 lbs - ft besure to lay a good bead of silicone at all 4 courners hope this helps.Double check the bolts more then twice.
snake is offline
post #3 of 5 (permalink) Old Jul 14th, 00, 04:06 AM
Drake
Wink
Agree,but I would also ditch the two rubber end seals.Use a good 1/4" bead of silicone instead.The rubber end seals move out of position when putting the intake on,and are usually the first thing to leak.
67 RS RAGTOP # matching
4X4 Chevy truck
4X4 Suburban
67drake is offline
post #4 of 5 (permalink) Old Jul 14th, 00, 04:17 AM
Gene
You torque the bolts from the inside out in a spiral pattern like this:
9 5 1 4 8 12
10 6 2 3 7 11
Retorque all of the bolts at least twice.
[This message has been edited by gheatly (edited 07-14-2000).]
gheatly is offline
post #5 of 5 (permalink) Old Jul 14th, 00, 06:28 AM
My 302 intake was leaking both oil and coolant. I not only used the 1/4" bead on the front and back but I also coated the port gaskets. In addition I put some silicone on the bolt threads. No problems with leaks since then.
ColoradoZ28 is offline
