steel or glass hood? - Team Camaro Tech
post #1 of 16 (permalink) Old Aug 4th, 01, 09:16 AM Thread Starter
Send a message via AIM to CamaroNOTcamero
i'm looking to buy a cowl hood for my car. its gonna be ethier a harwood outlaw 4" cowl glass hood or a steel cowl hood. which should i go for? what are the advantages of both?
CamaroNOTcamero is offline
post #2 of 16 (permalink) Old Aug 4th, 01, 10:58 AM
Wink
My metal "Goodmark" cowl hood fits right, looks stock, and has a built-in airbox. A glass one has the advantages of lighter (though I've never know how much) weight, and added clearance if you go with the 4". It won't look stock (is that important to you?) and you may have some cracking or special paint/prep issues.
'69 Garnet Red Convertible, Ivory over black, 350 w/turbo 400
POP D TOP is offline
post #3 of 16 (permalink) Old Aug 4th, 01, 11:25 AM
if you run an outlaw hood on the street, you better check with you local's to see if this hood would be illegal for the street. I know here in Pa, any 4"-6" over stock is illegal.
stay with a stock fiberglass cowl hood. I have one on my 69 and love it.
bruce
procamaro is offline
post #4 of 16 (permalink) Old Aug 4th, 01, 05:11 PM Thread Starter
is there a website where i could check my NJ laws to see how big of a hood i can put on? thanks for the info.
post #5 of 16 (permalink) Old Aug 4th, 01, 07:05 PM
I've got a glass cowl hood. Its bowes with any kind of spring on the hinges. 'Needed a rod to prop it up all the time. I just switched to a steel Goodmark hood. Its great!
1967 Camaro coupe since 12/24/66, '98 WS6 Conv, Y2K Corvette Conv
z51bob1 is offline
post #6 of 16 (permalink) Old Aug 5th, 01, 07:58 AM Thread Starter
what kind of glass hood did you have before?
post #7 of 16 (permalink) Old Aug 5th, 01, 03:12 PM
Check out www.carbonfibermanufacturing.com They have fiberglass and carbon fiber hoods.
Topsportsman is offline
post #8 of 16 (permalink) Old Aug 6th, 01, 05:35 AM Thread Starter
thanks i'll check into them, if its not too expensive i'll go with kevlar or carbon fiber.
post #9 of 16 (permalink) Old Aug 6th, 01, 08:16 AM
Sorry to but in on your question, but one of your replies (z51bob1)mentioned bowing with any kind of spring. I have a steel cowl hood that I just installed and with the original stock springs I get the "bow" referenced. I tried the weaker chrome springs and the hood fit correctly but would not stay up. I went to the local hardware store to buy something in between but to no avail. Any suggestions?
69nstyle is offline
post #10 of 16 (permalink) Old Aug 6th, 01, 08:23 AM
Rick
The springs aren't going to cause bowing, a weak structure will if I read this right. I have a steel hood and factory springs with no problem. If your steel hood is bowing from the weight, I suspect inadequate bracing. Is it OEM?
Rick Dorion
69 RS Conv,355,M20,4.10's
RickD is offline
post #11 of 16 (permalink) Old Aug 6th, 01, 09:05 AM
No it is an aftermarket hood. If I remove the springs, the hood lines up correctly. When it is bowing, you cannot push on it to make it line up so I don't think it is a structural problem. I may have to use a prop rod until I find something that will work. Thanks for your response.
69nstyle is offline
post #12 of 16 (permalink) Old Aug 6th, 01, 10:36 AM
Rick
Maybe I misunderstand what is meant by bowing. Could your hinges be worn? Mine were and made it impossible to get the hood to conform to the fender lines. The springs were fine.
Rick Dorion
RickD is offline
post #13 of 16 (permalink) Old Aug 7th, 01, 03:27 AM
What I mean by bowing is the front of the hood and rear of the hood line up perfectly with the fender (side view) but the middle sticks up a good 1/4" to 1/2". My hinges are a little wobbly, but when I remove the springs it lays perfect front, rear and middle which doesn't make any sense to me. I may have to give the new hinges a try. Thanks for your help.
69nstyle is offline
post #14 of 16 (permalink) Old Aug 7th, 01, 04:15 AM
Rick
I also had to remove the rubber bumpers in the middle of the fender to get my hood to lay down.
Rick Dorion
RickD is offline
post #15 of 16 (permalink) Old Aug 7th, 01, 05:38 AM
Charley
I have 2 camaro's that have Harwood Glass hoods on them and have had no problems with either of them one uses stock springs and the other has tie wraps that you drop over the hinge when it is open. I'm restoring a 69 Z and tried a steel repo cowl hood but it was about 1/3" narrower that stock gm hood. You couldn't get the gaps right. Ended up buying a GM cowl hood.
clill is offline
