bigblock swap - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 17th, 01, 06:33 PM Thread Starter
Lightbulb
i have a few questions about swapping my 396 into my 71 camaro. 1st. can i use standard motor mounts or do i need to offset like the 67-69's? 2nd. i want to change to HEI, what do i need to do to convert? 3rd.will my stock springs support the weight(is a 350 car)?
johnnyp is offline
post #2 of 4 (permalink) Old Jan 18th, 01, 03:56 AM
I have a 68 that I put a 396 into, I needed to change the motor mounts as well as the springs. The springs are of course the handle the extra weight and I was told you need to change mounts to make sure that everything lines up and is on the right angle. Good luck.
Draayer is offline
post #3 of 4 (permalink) Old Jan 18th, 01, 04:46 AM
Thumbs up
I'm starting the same thing on a 70 SS. Just dropped the heads off to be worked. I concur, springs and big block motor mounts needed. You might check ebay for HEI. I found one for 200 complete. May need to change radiator to 4 core as well.
stewart is offline
post #4 of 4 (permalink) Old Jan 18th, 01, 03:18 PM Thread Starter
thanks for the replies. i already have the HEI i just don't know how to wire it.Also wanted to know if anyone has any suggestions on jerking the old heater/a.c. unit and installing just a heater core unit? the oldone doesn't work at all.
71'Camaro Z/28 350/350TH (for now!)
johnnyp is offline
