68camaro - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 18th, 01, 07:06 PM Thread Starter
I have a stripped V8 Camero body. I want to know what heater set-up to use. The firewall has a small opening in it. What is the difference between a big block and a small block heater core opening.
sparkies is offline
post #2 of 6 (permalink) Old Jan 18th, 01, 07:54 PM
stevo camaro's Avatar
Hi sparkies, first, can I ask you, does this car have any front coil springs in it? Or a front clip? Or any glass? Rust in the trunk? No dash? Curious because of your location and a 68 that went that way not too long ago.
67 SS 396,4-sp
67 RS 327,4-sp
72 RS 350/350
69 4X4 suburban 350,4-sp
73 3/4 ton 454/400
Stevo Camaro's Toy
Our Muscle Cars
stevo camaro is offline
post #3 of 6 (permalink) Old Jan 18th, 01, 08:21 PM Thread Starter
I have puchased the body about 3 years ago with both doors subframe back window,dash,and has no rust
sparkies is offline
post #4 of 6 (permalink) Old Jan 20th, 01, 08:24 AM
Bryan Shook
I believe this is correct, I haven't seen a first gen Camaro firewall in a couple months but the small block cars have the hoses go through to the left (motor side) of the box.
Bryan Shook
Favorite Quote - Some people have shrinks. Some people have their garage.
My Father's 1968 RS 327!
My First Generation Camaro site
elcamino72 is offline
post #5 of 6 (permalink) Old Jan 21st, 01, 06:43 PM
Nick
Rarerat's Avatar
Hi Sparkies, The big block heater core pokes out in about the middle of the heater box in the engine compartment, and the small block comes out right behind the passenger side valve cover. I hpoe this helps.Nick
Rarerat is offline
post #6 of 6 (permalink) Old Jan 22nd, 01, 03:24 AM
The a/c cars had a square opening in the firewall with a round hole above the plemnum for the a/c harness, heat only holes were rectanglar with rounded outside corners. hope this helps.
69 rallye green X77 Z/28,1967 SS 396 Conv. 1974 c-10 454 swb
pipeman is offline
