396/SS or not - more info... - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 22nd, 00, 11:12 AM Thread Starter
Thanx to all you motorheads out there. MOre info -- 28 coil hood springs on what appeared to be a factory cowl induction hood
although no flapper door, relay or selenoid
was found. The engine block #is 3992406 which I think is from a pick-up. The tach red line is 5700(yellow)6000(red). The car also has an original tilt steering wheel.
Outside trim consists of wheel lip mouldings,
rocker mouldings and chrome sargents stripes
in front of the rear fender. The rear end
is a 273 non-posi unit that I'm unsure of
its origin but a 12 bolt. Windshield vin#
124379L523569. no factory air no tire sticker in replaced glove box, Original TH400 trans console w/gauge package. Thanx again
[This message has been edited by Bigblkss (edited 11-22-2000).]
Bigblkss is offline
post #2 of 3 (permalink) Old Nov 22nd, 00, 05:24 PM
Single fuel line coming from tank? If so then
it might be a SS 396/375 car. The 6000 RPM redline tach says it might be....
'69 SS 396/375hp L78 M21 3.73 Fathom green/medium green interior
http://albums.photopoint.com/j/ViewP...695&p=33013081
Bob Jenkins is offline
post #3 of 3 (permalink) Old Nov 23rd, 00, 07:54 PM
On the right side of the tranny above midway point on oil pan there should be a tag about 2 1/2" x 1 1/2" riveted to the case.
A two letter code would tell you trans application. CX is a TH400 for a 396ci/375hp car. There's also a 3 digit build date. VIN # is stamped on a left side on case just above oil pan mid-point.
1969 LA Z28 - 42k miles - PoP & build sheet - original drivetrain(DZ/M21/BV), paint(57 57) & interior(723).
1967 v-8 base coupe, three on the tree, 87k.
[This message has been edited by Ed Ernst (edited 11-23-2000).]
Ed Ernst is offline
