Sub Frame offset - Team Camaro Tech
post #1 of 15 (permalink) Old Jan 19th, 01, 08:40 AM Thread Starter
Joe
I have a 69 that was stuffed with hopped up 396 and TH 400. It has 1 3/4" long tube headers (not block huggers). It appears that
the subframe was offset to the passenger side byabout 1/2" to provide header clearance for the srteering box. I would like to recenter the subframe. Has anyone else encountered this and is it a straightforward process? The body and frame show no signs of damage; it appears to be intentional.
Joe G is offline
post #2 of 15 (permalink) Old Jan 19th, 01, 08:44 AM
Simply use a tape measure. Measure from a point on the subframe to the sheetmetal lip below the rocker panels. Just make sure your measurments are square. I had to do this when i installed my subframe to get it centered. For anything like this the general rule is to find a good permanent referance point to measure from.
jvolk81 is offline
post #3 of 15 (permalink) Old Jan 19th, 01, 08:52 AM Thread Starter
Joe
Thanks for the quick reply. I just bought the car and have a steep learning curve ahead of me. I have been out of hot rods for 20+ years.
To move the subframe all I have to do is loosen the attachment bolts and slide the frame over?
Of couse I will have to change the headers, first.
Joe G is offline
post #4 of 15 (permalink) Old Jan 19th, 01, 08:53 AM
I may have the wrong mental picture of this, which wouldn't surprize me, but the steering box on a '69 is mounted inside the frame and moving the whole subframe one way or the other would not effect engine or header clearance. Right????
onemorecamaro is offline
post #5 of 15 (permalink) Old Jan 19th, 01, 09:07 AM Thread Starter
Joe
After reading your note, I went back to the garage to look and measure. You are right. The steering box moves with the sub-frame. I guess I'll have to figure out something different.
Joe G is offline
post #6 of 15 (permalink) Old Jan 19th, 01, 09:15 AM
Carl
John,
I thought I had the corner on the market for bad mental pictures!
You are correct on the subframe-header issue. Changing the alingment will not correct a steering box interference issue.
The Body By Fisher chassis manual has dimensions and gauge points for installing your subframe.
You may want to perform a search in the suspension section. There is a lot of good information there.
Click here to see see my car and hear 5-speeds. http://www.geocities.com/casanoc
CarlC is offline
post #7 of 15 (permalink) Old Jan 19th, 01, 09:27 AM Thread Starter
Joe
Thanks for the help. Any suggestions on the easiest way to slide the frame over? I am planning on doing it my garage with the body supported on jackstands.
Joe G is offline
post #8 of 15 (permalink) Old Jan 19th, 01, 10:52 AM
Speaking of mental, If you move the subframe over, you are creating another problem caled alignment. Big blocks are installed in Fbodies all the time without such drastic measures, things such as correct frame mounts, motor mounts and crossmember will go a long way in getting everything lined up properly. You may even have the wrong header for you application. btw the subframe alingments holes are below the firewall, outboard of the bushings,and you can insert a .610 (thanks John Z ) rod in them to check if everything is lined up.
69 rallye green X77 Z/28,1967 SS 396 Conv. 1974 c-10 454 swb
pipeman is offline
post #9 of 15 (permalink) Old Jan 19th, 01, 12:37 PM
Rob
Sliding the subframe could also change how all of the sheetmetal on the front is aligned. If you don't have an assembly manual, get one.
Rob Rice
[email protected]
http://members.xoom.com/robr54
RobR is offline
post #10 of 15 (permalink) Old Jan 19th, 01, 02:49 PM
Smile
It seems like alota the cars are off both front and rear, stock too. I know mine's off some.
Do a search on this because we beat it up awhile back. pdq67
post #11 of 15 (permalink) Old Jan 19th, 01, 09:30 PM Thread Starter
Joe
Thanks for the help, guys. Looks like I need to do a bit more research before I dive in and do something stupid.
Joe G is offline
post #12 of 15 (permalink) Old Jan 20th, 01, 01:43 AM
Pardon me for stating the obvious, but big block frame mounts are offset to the right to make clearences for the motor. Please measure the subframe completely before doing anything. If it measures straight, maybe you have a mount problem. Has the car ever be hit?
Toby Keen is offline
post #13 of 15 (permalink) Old Jan 20th, 01, 06:13 AM
If you'll read the assembly manual, you insert a .610 pin in the gaugeing holes into the sub frame, and that is supposed to get you in the ball park for sub frame alignment instead of guessing and haveing to use a tape measure.
67 Camaro SS Conv.
70 Challenger R/T Conv.
ragtopman is offline
post #14 of 15 (permalink) Old Jan 20th, 01, 10:43 AM
David Pozzi
davidpozzi's Avatar
Your big block is supposed to be offset to the passenger side, or else it would hit your steering box.
Look at the big block fan shroud, it is made offset to allow for the engine being off center.
Take your time and learn more about your "new" car here. There are no "stupid" questions here!
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #15 of 15 (permalink) Old Jan 20th, 01, 05:36 PM
stevo camaro's Avatar
Joe G, I'll be in martinez next week. I could stop by and take a look see with ya if you want. It's just getting over that bridge at 6:00 that's tough. LOL
67 SS 396,4-sp
67 RS 327,4-sp
72 RS 350/350
69 4X4 suburban 350,4-sp
73 3/4 ton 454/400
Stevo Camaro's Toy
Our Muscle Cars
stevo camaro is offline
