Carb return spring bracket - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 20th, 01, 05:42 AM Thread Starter
I need a good carb return spring setup for my 69 350 camaro. The carb is a Holley 650dbl pump on a Torquer manifold. I have a rod linkage from the firewalll pedal lever to carb. I also have the need to attach the TH350 kickdown cable. I am using a standard moroso air cleaner and 3" K&N filter. This is all new and the car did not have anything on it before. I have nothing to work with and I dont want to get junkyard parts and hack an ugly mess together just to solve the problem. I am looking for a clean and functional setup i can buy. I am up for a little Fab work but I rather spend time on more important projects. Thank you for your time. Eric.
vonzipper is offline
post #2 of 4 (permalink) Old Jan 21st, 01, 02:23 PM
Summit offers a throttle return spring kit that will fit Holley carbs models 2300,4150/4160. It's part # SUM-G1327 the price is $10.99 In case you don't have one of those models there is also a return spring bracket SUM-G1339 for $7.50 Give them a call I'm sure they can help 1-800-230-3030. As far as the kickdown linkage for the TH350 I'm currently looking into that so I'll let you know what I find out.
69 Camaro
marine is offline
post #3 of 4 (permalink) Old Jan 21st, 01, 06:18 PM
Shiftworks has the kickdown bracket------------------
68 RS, Ash Gold,pwr windows,Hounds tooth
[This message has been edited by CA420 (edited 01-21-2001).]
CA420 is offline
post #4 of 4 (permalink) Old Jan 21st, 01, 06:54 PM
Nick
Rarerat's Avatar
Cool
I have seen just what you need ai Checker auto it sells for around 20 bucks. It holds the kick down cable and return sping and its chrome plated. I used one on my street rod and it worked great.
Rarerat is offline
