396-325HP Th-400 kickdown switch bracket - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 24th, 00, 08:34 PM Thread Starter
When converting from a Q-jet carb, will the Th-400 kickdown switch bracket work on a holley #3310-1 carb?, or will I have to find a different bracket?. Still a dealer item?, or will I have to deal with repo junk?. I cant be the only one that converted from the Q-jet carb and cast iron intake to the L-88 alum. intake and 3310-1 Holley carb, any ideas or suggestions welcomed, thanks.
P.S. Is my old intake worth anything or should I give it away?.
bigblockkid is offline
post #2 of 4 (permalink) Old Nov 25th, 00, 04:56 AM
William
William's Avatar
QJ & Holley brackets are different; I think the Holley bracket is repro. You might find a used bracket at a Camaro vendor.
William is offline
post #3 of 4 (permalink) Old Nov 25th, 00, 07:09 AM
Wink
With regards to the intake, if you have the time clean it up, snap a picture of it and stick it on ebaymotors.com. That place is definitely a seller's market! I can't believe the prices some stuff goes for at times.
'69 Restification
JonT is offline
post #4 of 4 (permalink) Old Nov 25th, 00, 11:16 AM
the 400 was a electric switch attached to the gas pedal linkage on 70 models. Are older models different?
ClintB is offline
