327 performance mods - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 14th, 00, 02:57 PM Thread Starter
Bob
OK here goes. I've got a '68 that I've had for several years and I'm finally ready to upgrade the drive train. It's an original 327/210, powerglide, 2.73 rearend. I'm in the middle of a rearend swap to a 8.5" 10 bolt with a set of 3.73 gears. Next I'll be gathering up the parts to covert to a muncie 4 speed. Question I have is what to do with the 327 ? What would be the best bolt on mods? I was thinking about an edelbrock performer RPM carb, intake, and cam. What knd of horsepower boost would one expect from these changes? Any other recommendations? I'm looking for a good driving street machine that can light them up when the urge hits me. Thanks for any comments.
Bob H. 68 Camaro, 72 Nova, 82 Vette. Check out my WEB site.
http://www.geocities.com/bh3chevy/Bobs_All_Chevy
bh3chevy is offline
post #2 of 7 (permalink) Old Mar 14th, 00, 06:07 PM
I would pass on the Edelbrock cam, these are one size fits all. If you check out there specs they have tons of duration between gross lift and .050 lift, this means the valve opens very slowly. There are many cam manufacturers out there with more modern cam profiles which open much more quickly. I would stick with a name brand such as Comp, Isky, Crane, Lunati, etc. Good luck.
Steve R is offline
post #3 of 7 (permalink) Old Mar 14th, 00, 06:21 PM
David Pozzi
davidpozzi's Avatar
I think you have tiny valves in those heads. Get at least 1.94 intake size heads or your other mods will be wasted.
davidpozzi is offline
post #4 of 7 (permalink) Old Mar 15th, 00, 03:59 AM
Keep in mind that with a radical cam, the torque converter limits your idle speed quite a bit. Street driving can be a real bear without a high stall converter running a large cam.
tom3 is offline
post #5 of 7 (permalink) Old Mar 15th, 00, 05:39 AM
Bruce
bob,
my first 327 engine was the best i've ever had. i have the urge to get another one and build it to the same spec's. it was in my 68 camaro with 12 bolt, 4.10 posi,turbo 400 with 2000 stall. it was bored .030 over(331), trw flat top pistons(10.0:1 comp)64 cc heads, 1.94 intake valves and i believe 1.50 exhaust, holley strip dominator intake, 650 holley double pump, 474" lift,292 dur., erson cam, high volume oil pump. it ran great on the street and it also won a lot of races, of course, not on the street??????? yeah right, those were my dumb years.
and if my kids want to some day go racing, i'd build them that exact engine, but with a little more modifications.
do yourself a favor, and put some money into the cylinder heads. that's where the power is at. and make sure you get parts that are matched for each other. a mis-matched engine will only do one thing and that is bring you headaches. match your power range, of the cam, with the intakes power range, get the right size carb, a good set of heads and a good ignition system and you'll be a happy camper.
good luck,
bruce
bruce69camaro is offline
post #6 of 7 (permalink) Old Mar 15th, 00, 05:48 AM
Thumbs up
What bruce said!!!
71 Camairo
71 Camairo is offline
post #7 of 7 (permalink) Old Mar 15th, 00, 08:11 AM
Gene
I ran some dyno simulations for one of the other guys on the site with a 327. I ran several cams and he ultimately picked a COMP 268H. The COMP 260H also posted good numbers. These cams give very good low end torque (which is what a 327 needs) and run well up to 5,000 RPMs.
Hugger Orange & white 69 Camaro with supercharged 350, Tremec TKO, and 3.73 12-bolt
gheatly is offline
