67 camaro p/g to turbo 350 - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 27th, 01, 04:20 PM Thread Starter
I AM RESTORING A 67 RS CAMARO WITH A RARE FRONT BENCH SEAT FOR MY WIFE AND I WOULD LIKE TO REPLACE THE P/G TRANS WITH A TURBO 350. THE PROBLEM IS I WOULD LIKE TO KEEP THE SHIFTER ON THE COLUMN AS ORIGINAL. HAS ANY ONE DONE THIS BEFORE OR HAVE ANY SUGGESTIONS.
Jesse G is offline
post #2 of 5 (permalink) Old Mar 27th, 01, 04:40 PM
David Pozzi
davidpozzi's Avatar
Hit the search button on the upper right of this page and search the engine and drivetrain section in addition to this one.
I did this swap on a 68 with console, had to replace the flex plate with one that had two bolt patterns, large and small (three holes for each), bend the cooler lines to fit, and set the shifter up so when in second gear in the trans, the shifter said LO.
I would think your column shifter would work the same way. Just put it in park, with the trans in park, like you would for a PG. You won't be able to select first gear manually, but most people don't anyway.
You can use your PG trans yoke, I don't know if the later TH350 would have a larger output shaft? The spedo cable should work, the trans mount is the same, the trans length is the same.
It was like a new car with the new transmission, you really need a passing gear, and the old PG was allways at the bottom of high gear when passing.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #3 of 5 (permalink) Old Mar 28th, 01, 11:29 AM
Eric
I did this swap and kept the column shifter. Don't bother searching archives - there's lots of stuff on consoles but nothing I found useful on column shifters. This is what I did.
The original shift rod that goes from the steering column to the pivot bracket (the bracket that bolts to the frame with 3 bolts) is fine, only a little adjustment was required.
But the rod that goes from the pivot bracket back to the trans did not come close. Instead of the powerglide piece, I found a longer rod from a th350 equipped full size car. I bent it to clear my header and put the adjustment collar on the end closest to the trans. (Just a straight rod with the collar on it).
Then I made a new shift lever for the trans to replace the "U" shaped one that comes on the TH350. I used 1/8" by 3/4" flat bar stock (thanks Home Depot). I cut a square hole in one end to fit on the trans (using the TH350 bracket as a pattern) and put two 90 degree bends (opposite directions) in the bar stock so the end is about an inch away from side of the trans and points down when the trans is in low 1 (doesn't look like a "U" but more like a "Z"). Then I drilled a round hole in the other end of the new bracket and connected the rod to it.
Now where you drill the round hole in the end of your trans bracket will determine how far apart the actual gears are compared to the Park-R-N-D-L marks on your shifter. In other words, if the hole is off a bunch, when you shift into Park you may be in park, but the shifter may read "N" or "D" before you actually get the trans into reverse. Mine is set up so that Park-R-N-D-L all line up - 1st is actually to the right of the L mark on the shifter and L2 lines up with the "L" mark.
If you need a pic let me know, I could probably send one via email. This is hard to describe in writing. It's not that hard once you understand what to do. Just takes some patience . . .
Eric68 is offline
post #4 of 5 (permalink) Old Mar 29th, 01, 07:29 AM
Make sure the PG is the correct one for the 67......my PG was an old shortie style and the yoke was different and the driveshaft was longer.
68 RS, Ash Gold,pwr windows,Hounds tooth,355/T350,Autometer guage pod
CA420 is offline
post #5 of 5 (permalink) Old Mar 29th, 01, 01:58 PM
Chris
130fe's Avatar
try checking out www.shiftworks.com
They might be able to help you.
[This message has been edited by 130fe (edited 04-01-2001).]
130fe is offline
