VORTEC Heads - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 16th, 00, 09:57 AM Thread Starter
Cool
What modifications are required to bolt on GM's Vortec (1999 76cc) cast iron cylinder heads on an earlier 350 block? Is anybody out there looking for a set of these heads serial#333417369 that are almost new? Will sell for $250.
sshowell99 is offline
post #2 of 5 (permalink) Old Mar 16th, 00, 10:17 AM
Thumbs down
33417369...90-up...350..........Gen.I Goodwrench crate motor,
"Hecho en Mexico", 76cc
They are a dime a dozen
Thanx anyways,
71 Camairo
71 Camairo is offline
post #3 of 5 (permalink) Old Mar 16th, 00, 03:19 PM
Vortec heads require the new style intake manifolds. Hold down bolts are straight instead of angled.
68SS ZZ4, 4sp T-10, 12 bolt, getting painted
78Z28, 330hp vortec, TH350, 10 bolt (just finished)
1st & 2nd GENGuy is offline
post #4 of 5 (permalink) Old Mar 19th, 00, 02:47 PM
The new Vortec style heads are awesome. Commonly known as "the best bang for the buck." I read in an article from one of the high performance mags, that these heads, even with 1.94/1.50 valves, flow better than the World Products Sportsman II heads with 200cc intake runners, and 2.02/1.6 valves! There are two drawbacks to the Vortec heads. You have to run a different intake. I just happen to have an Edelbrock catalog handy. PN#2116 is the Performer. It is basically a stock replacement performance intake. It has an rpm range of idle to 5500 rpm. If you want the high rise dual plane Performer Rpm, Pn#7116. It has an rpm range of idle to 6500rpm. The last time I priced the RPM, it was about $175 through Jegs. The other drawback is if you are running a 400 small block, you have to have steam holes drilled. They also don't have screw in studs. I hope I have been of help.
Jeremy Mc.
69Man is offline
post #5 of 5 (permalink) Old Dec 25th, 00, 04:15 PM
I have just got an engine 350 with 350 v head's performer intake, heads planed, 30 over will be dropping it in this week.any thing i should watch out for with these head's what kind of hp these head kick out?
81'bird is offline
