Pulling Steer Col... - Team Camaro Tech
post #1 of 2 (permalink) Old May 29th, 01, 03:26 AM Thread Starter
Other than disconnecting rag joint and unbolting from dash, what else is required to pull the steering col in a 69?
Thanks!
RFrenette is offline
post #2 of 2 (permalink) Old May 29th, 01, 09:27 AM
Not sure if the 69 and the 67 are the same but I believe they are very close.
You are right on:
2 rag joint bolts - note they are both different dia and thread to make sure they go back on the in the same orientation.
Then you should have 2 nuts holding the underdash steering clumn mount bracket. There are 3 on a 67.
In addition you have 3 bolts in the Steering Column to floor cover. This cover holds a firewall seal in place. The cover is a 2 piece design and has 2 screw attach each half around the column.
Very easy removal.
Let me know if you have any questions - I just re-installed mine yesterday.
- John
[email protected]
67' Convertible Camaro -"SS Clone Car"
402BB, TH400, 12 Bolt Posi w/ 3:73's
[email protected]
Pennsylvania
Picture Link: http://www.geocities.com/jjknotts/1967Camaro.html
jknotts is offline
