Auburn or US Gear posi unit or????? - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 12th, 01, 10:14 AM Thread Starter
I have an 8.2 inch open rear end that I am going to be doing a rebuild on. What brand should I use? I only put about 3000 miles a year on the car (topps), and go to the strip 10-15 times a year (no slick)drag radials. Please let me know what brand posi you are using?
PERKS67-396 is offline
post #2 of 8 (permalink) Old Feb 12th, 01, 04:51 PM
Freddie
I own a performance rear end shop and I've put a lot of different posis in. I do not recomend the Auburn unless there is nothing else available. The US Gear unit is a copy of the Eaton. It may be built a little heavier than the Eaton, I think the springs are stronger which will make it lock up better but may cause it to pop a lot. I would probably go with the Eaton. www.eatonposi.com
'69 RS/SS396 pro street
427/4spd/9"
big gear head is offline
post #3 of 8 (permalink) Old Feb 12th, 01, 05:04 PM
I believe the US Gear posi clutches are rebuidable, but the Auburn's are not.
BIGDOG454 is offline
post #4 of 8 (permalink) Old Feb 13th, 01, 02:44 AM
Will did Jon O hang it to you. Will I'm seting here with a heat pad on my hip I must have got out to much yesterday. I'm going to try to come by and see you one day this week. Hows the old man doing have not heard from him in a long time. Tell him I said to go build a Ford HA HA.
69 RS Z/28 96 IMAPLA SS 82 C10 300HP 350
Tim Meredith is offline
post #5 of 8 (permalink) Old Feb 13th, 01, 04:48 PM
Freddie
Tim
Yea, $44 for a oil pan gasket. That hurt. Come on over and help me put my Camaro back together. You can lay on your back and clean oil off the bottom of the floor can't you?
427/4spd/9"
post #6 of 8 (permalink) Old Feb 14th, 01, 10:10 AM Thread Starter
Big Gear Head, you said you own a performace rear end company. Where is it located, name, number? Im getting ready to do a rebuild and need to buy some parts.
post #7 of 8 (permalink) Old Feb 14th, 01, 03:25 PM
Perks67,
I just installed a new Moser 12 bolt, bought it with an eaton posi unit. I here they are very reliable and rebuildable. The 8.2 that came out of my car is equipped with a PG diff, it seems to work great, I bought it through reider racing rears and gears. I set it up with US gear 4.56 and had 3.73 on it as well also a set of moser axles. What do I do with it now! Good luck
67ragtp is offline
post #8 of 8 (permalink) Old Feb 14th, 01, 04:34 PM
Freddie
perks67,
You can contact me at [email protected]. I'm in Central City, Ky. Name is Byars Performance. I'm Freddie. This is a small business and I try to keep it that way so I can specialize in rear ends. That means I also have to have a real job to keep the family fed.
Look, 427 posts!
427/4spd/9"
[This message has been edited by big gear head (edited 02-14-2001).]
